Results 1 to 10 of 14
Thread: discovery 2 cruise problem
    Bairnsdale enjoying the rural view no rooftops to see here
    driving home today the cruise decided not to work upon investigation I found f4 under the bonnet (washer) and f25 under dash (stop light ) blown replaced these and its all working .....any ideas ?
    have a good one :D ken :wasntme:
    MY07 L320 RANGE ROVER SPORT MORE GOODNESS TO COME
    MY03 D2A TD5 EXTRA GOODIE ENHANCED :D now parting from life
    1996 D1 300TDI GONE
    08 ford ranger c/c
    WRECKING DISCOVERY 2
    PM ME FOR WHAT YOU ARE LOOKING FOR
    Perth WA 6149
    Yep no brake lights will disable cruise control. I had the same problem when the brake light fuse blew a few years ago. As to why it may be just one of the things but if it blows again start digging a bit deeper.
    Steve
    Jan 2013
    A water logged horn can blow the horn fuse and then the cruse control doesn't work either, I assume it somehow disables the steering wheel buttons. This happened on my 2003 TD5.
    Marc
    Ok so it did it again today headed to Melbourne on the way home about 20 ks out happily cruising at 100kmh and all of a sudden the cruise disconnected when it does it an alarm chimes but no lights on the dash so I am thinking it is between the fuse box and the brake light switch
    Sent from my SM-G900I using AULRO mobile app
    1996 D1 300TDI GONE
    08 ford ranger c/c
    Perth WA 6149
    It could be there or plenty of other places. Doubtless you've checked the fuses again which will give you a clue. Did you apply the brakes, use the indicators, or do anything immediately before or did it just happen?
    Going deeper other areas to look at are oil in the ECU loom, at the red plug on the ECU ( if you have a td5), this caused me problems with cruise control actuation in times past. When my brake light fuse blew it only happened with a trailer attached and the problem was eventually traced to the wiring to the 7 pin plug.
    Steve
    Quote Originally Posted by Rok_Dr View Post
    No
    Steve
    That's exactly the same as you have said both times with the trailer attached and today I replaced the fuse and it blew straight away I will try without the trailer tomorrow and check the trailer plug although I had ruled that out as I hadn't hit the brake pedal
    1996 D1 300TDI GONE
    08 ford ranger c/c
    Perth WA 6149
    If it is trailer related also check the electric brake controller wiring (if fitted) and the trailer wiring as well.
    Steve
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Ken, Check your trailer wiring, one of your moo cows might have eaten some wiring.
    They don't get anywhere near my car
    1996 D1 300TDI GONE
    08 ford ranger c/c
    Changed the trailer harness and plug yesterday just to rule it out spent most of the day moving hay on corrugated roads and it hasn't happened yet
    1996 D1 300TDI GONE
    08 ford ranger c/c
