Thread: Any clue where this might have fallen off?
    Yanchep, WA
    Just found it in my drive. I've just had the PAS pump, water pump and aux bracket off. All bolts are present as far as I can see.
    12mm head, roughly 24mm long (end to end). Has evidence of oil on the end of the threaded bit.
    I don't recall using 12mm, but...
    2002 Discovery II TD5.
    Anyone?
    May 2012
    Adelaide Hills, SA
    Best I can suggest is a mirror and a good light. Use the mirror to look from angles you can't get at without it, you might even have to shine the light at the mirror to light up some of the areas.
    Is there a possibility that it was just lodged somewhere on the motor, lost and replaced before, and just been jiggled loose with you working on the vehicle?
    Mike
    schuy1 Guest
    My bet is what nismine01 suggests, The only 12mm headed bolts in that area are the aux mounting as far as I know. I reckon some1 has dropped it and it has gone down under the aircon compr against the block. Been there done that
    Cheer Scott
    Yanchep, WA
    Thanks guys. Here's hoping! It could be off my wife's car, or even thrown up off the road about 2 meters away.
    We're heading down to Bald Rock NP in the morning. Likely to find every man and his dog beat us there! ;-)
    May 2009
    Tatura, Vic
    Not saying that they don't exist, but I have never seen a 12 mm headed bolt on a LR.
    Is the wife's car Asian. 12mm was common on Asian cars.
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Yanchep, WA
    Quote Originally Posted by d2dave View Post
    My first thought was exactly that, but I'm not that experienced in the "deeper" mechanical areas of the Disco. 8mm, 10mm and 13mm seem to be the sizes I've encountered for the most part.
    My wife's car is a Ford Focus, but I think it was one of the South African built ones. I better take a peek under hers! :-o
    Jul 2014
    PERTH, WA
    Quote Originally Posted by Wil2k View Post
    Anyone?
    Hi Wil2k,
    It is just possible that the bolt you found did not come from either of your cars. It could have been picked up anywhere on the road (or at a service station?) by your tyre tread, and been transported to your home before falling out.
    Had it been a nail or a screw in this circumstance, you might well have had a flat tyre to deal with on the road. But being a bolt, that's much less likely.
    I have seen black bolts like the one you show on many Japanese cars, but not on a Land Rover (quite apart from the 12mm size).
    Just a thought.
    Cheers, AndrewMilne
    Yanchep, WA
    Well we did 750 kms after this post. No (new) leaks, no rattles, no catastrophic failures. Guess it wasn't mine after all! Any clue where this might have fallen off?
    Thanks guys, for being an extra set of eyes. Much appreciated.
    May 2003
    On The Road
    Glad to hear it
    Yanchep, WA
    ...although my passenger tail lights fell out of the bumper and melted a bit somewhere just before Warwick. The bits of black plastic in my driveway... Well... We know where they came from. Any clue where this might have fallen off?
