Results 1 to 10 of 15
Thread: arb bull bar
    Feb 2013
    Queensland
    arb bull bar
    Hi all I have an arb Bullard on my d2 the bar isn't a winch bar my question is can I make it into a winch bar and if so how hard is it thanks.
    Blairgowrie, Vic
    Talk to ARB in Kilsyth 03 9761 6622 - they may help you and then again....
    Cheers and good luck.
    Pete
    Dizzie, 08 D3 TDV6 SE
    Cranbourne North
    You will need a winch cradle. The winch on vehicles with air bags mounts this way, not directly to the bull bar. The same mounting holes for the bull bar are also used to hold the cradle. You will be restricted to a low mount winch. The bull bar you have now should hopefully have a slot for the cable or rope to pass through. I will be, when I get the shed sorted, fitting up a bull bar and winch to my DIscovery 1 .
    Cheers Hall
    May 2009
    Tatura, Vic
    Quote Originally Posted by Hall View Post
    Cheers Hall
    Incorrect. I have a D1 and D2 both with SRS. Both have an ARB bar. On the D1 the winch mounts to a cradle which is bolted to the chassis.
    On the D2 it is mounted directly to the bull bar, same as an older non SRS vehicle.
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    schuy1 Guest
    what d2dave says makes sense. If it was chassis mounted behind the bar it would interfere with the crumple zone that the SRS require to trigger, Not an issue in an early D1.
    Cheers Scott
    Bairnsdale enjoying the rural view no rooftops to see here
    Quote Originally Posted by d2dave View Post
    Mine is the same
    Sent from my SM-G900I using AULRO mobile app
    have a good one :D ken :wasntme:
    MY07 L320 RANGE ROVER SPORT MORE GOODNESS TO COME
    MY03 D2A TD5 EXTRA GOODIE ENHANCED :D now parting from life
    1996 D1 300TDI GONE
    08 ford ranger c/c
    WRECKING DISCOVERY 2
    PM ME FOR WHAT YOU ARE LOOKING FOR
    May 2015
    Williamstown, Victoria
    Photo's please
    Hello, any cahnce you could post a photo? and what winch do you have? I'm guessing you have to cut out a hole in the bar?
    Julian
    Build date 11th Oct 2003
    LROCV #1410
    Dec 2009
    Baldivis WA
    Quote Originally Posted by Bohica View Post
    Julian
    I have an ARB Deluxe bar on my D2a. No cutting required for a low mount winch. The Deluxe bar is SRS and winch compatible.
    I've got a Runva 11XP Premium winch fitted. I did buy the addition ARB spaced and offset hawse mount.
    2014, MY14 Discovery TDV6, Fuji White (2018-Now)
    2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
    2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
    Dec 2009
    Baldivis WA
    Seems I can only post one photo at a time via my iPhone?
    Dec 2009
    Baldivis WA
    Hawse spacer/offset kit. Hard to see in the photo.
