Results 1 to 10 of 12
Thread: brake controller that wouldnt mind being in a series ii
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Took towtent for a cruise behind the 59 swb tonight and it towed it like a dream.
    stopping it was okay but i would like to take advantage of the electric brakes on towtent so my question is
    what would be a good electric brake controller to have in the old girl?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Aug 2010
    Sunbury, VIC
    Just a thought bubble, but if you're going to tow it with more than one vehicle, would you be up to fitting a trailer mounted brake controller - we are about to install a system like this on a large trailer mounted generator at work so a controller isn't needed for the tow vehcile. The unit we are looking at has a Bluetooth control panel that is moved from vehicle to vehicle and runs on 2 AA batteries to adjust the brakes and to operate them manually. No wires needed in any tow vehicle, just a 12 volt supply on the trailer though - this can be the breakaway battery, but it would need to be charged more regularly than normal, or hooked to a small solar panel.
    Not sure what they cost yet, but maybe an option?
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    my other tow vehicle already has a controller
    i thought about an on caravan unit so
    1) not seen the bluetooth unit, will have to go have a peep
    2) i also noticed that by the time you muck around with extra batteries and wiring it costs more than the 140 bucks something like a tekonsha voyager and harness costs... (how well they work i am not sure as yet either)
    off to go do some more investigation...
    teshonka P3 type with a cradle configuration.
    one controller, multiple cradles in multiple vehicels.
    peice of cake.
    IT even uses standard connectors so if you want to be really really cheap about it you can just make extension cables to fit the once cradle to multiple vehicles
    Feb 2013
    Ballarat,Vic,Aus
    peice of cake.
    Tekonsha IQ will do that too .... for a fraction of the cost
    Tekonsha Primus IQ Brake Controller Suit Caravan Trailer Boat | eBay
    very cheap for what they are. I wouldn't trust anything that is wireless ... yuk, it would be sure to fail at the exact moment you desperately needed it to work!
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
    Aug 2010
    Sunbury, VIC
    Ye of little faith Shane.
    It is perfect for the application we need it in - hiring it to multiple people who won't have a brake controller fitted.
    I run quite a few wireless systems at work of varying types - I've never had one just stop working for no reason, but I see your point - wouldn't want the first time to be when I had a van starting to tail slap.
    Feb 2013
    Ballarat,Vic,Aus
    Quote Originally Posted by Homestar View Post
    stick a wireless backup camera to your car ... and see how hopeless they are .................. Just as you back towards the hitch ............ bye, bye picture
    Proper cars--
    Modern Junk:
    Aug 2010
    Sunbury, VIC
    Ah, yes - but I wouldn't spend $50 on a wireless system....
    Last one cost me over $2K - and I get 15KM line of sight with that one, and around 3KM in hilly or built up areas.
    Oct 2007
    Brisbane West
    If i changed tow vehicle it would be a Red Arc Tow Pro that can be set to full manual for off road use and full auto for on road use. Plus its Aust tech with Red Arc's usual great support (no i dont work for them).
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    have ordered an iq and will see how it goes
    at under $80 it is as cheap as the on trailer units and if i like it i will get an extra caddy or 2
    thanks all
