Do you need to charge 2 iPads at once? I know you can get a twin port unit that has a 2.1 amp port and a 1 amp port but never seen a twin 2.1 amp unit - I wouldn't mind one myself if you find one.
Hi all. Looking for Narva style 2 usb socket I can mount and wire in...but need both ports to be 2.1 amp min for iPad charging. I dont want the Belkin plug in style.
In our vehicle 2 iPads being on charge is common. I've got this stuck to the rear of the center console. 2 x 2.4A + 3 x 1A outputs.
No arguments since I got it.
Orico MPU-5S-BK 5 Ports USB Car Charger from MSY.
_________________________
1996 D1 V8 - gone
2002 D2 Td5 ES- gone but still running elsewhere
2013 D4 SDV6 HSE - gone
2023 Defender 110SE D300
Not exactly what you want but I just bought one of these for the L322.
See eBay item no. 131459673783
What about one or even 2 of these -
CAR Truck Boat Accessory 12V 24V Dual USB Charger Power Adapter Outlet K69A | eBay
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
P38A if i could get that with twin hi amp ports im in.
I suggest try this?
http://www.aliexpress.com/item-img/1... | Alibaba Gro
adapter 12v Picture - More Detailed Picture about Quality Super 3 USB 5V 6.3A USB Car Charger Adapter For iPhone / SamSung S6 S5 S4 S3 Note 4 3 / all mobile phone / Pad / Car DVR Picture in Car Charger from BestBuyStore | Aliexpress.com | Alibaba Gro
Hope that link works,
These may get you by until they can find fittings
Thanks gents. It's odd that 2 X 2.1 or greater amps cannot be had in the same socket. I might use the little 2 socket jobbie from Ali and recess it into the console somewhere and put one in the back.
I just use a double USB ciggie plug. Gives me 2 x 2.4amp usb points. Will charge both an iphone and iPad with bothing running GPS apps and recording track.
Pretty sure its this one. And the lightning lead works fine.
|Belkin Dual Car Charger with Lightning to USB cable - Apple (AU)
