Results 1 to 2 of 2
Thread: Disco 2 V8 lpg RPM pickup wire connection?
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Hi all, I'm installing a Sequenetial lpg system from a donor vehicle.
    Currently the system had it's RPM signal wire connected to a coil wire.
    Reading the manufacturers install notes, it says not to install it to the coil.
    Where else could I connect it to to receive the RPM signal?
    Blairgowrie, Vic
    Pick up point
    Hi Mario. Just saw this.
    I used the tacho drive wire - picked it up behind binnacle - the rhs plug on top of the instruments - afair, it is the slate and white wire on pin 15. Check it because my memory often cheats me! Solder a parallel cable through to the join with the lpg ecu relevant cable.
    Pete
    Dizzie, 08 D3 TDV6 SE
