Thread: Fitting country CVs to range rover
    Mar 2010
    Kew, Victoria
    Hello all,
    I've bought a maxi front diff and I want to fit country CVs for added strength. I've heard that it have to modify something to make them fit.
    Anyone have a step by step?
    Cheers Nat
    Yinnar South, Vic
    If I remember right, you need to machine the inside of the spindle as the County CV has a radius as the outer shaft is conjoined with the CV bell, also need end cap to suit range hub and splined outer
    Personally I would not bother, I've broken more Country CV's than early rangie ones, I'd be fitting aschroft
    May 2009
    Quote Originally Posted by rovercare View Post
    Agreed
    Dec 2014
    FNQ
    +1 ashcroft.
    when you look at the cost of ashcroft CV's, plus the time and labour involved in doing repair / replacement work on CV's, then the actual cost of the ashcroft cv is not as horrible as it sounds.
    Or to put it another way, you'll be replacing broken county CV's a few more times before you inspect the ashcroft cv for wear once. Not to mention the ashcroft cv is actually serviceable if worn.
    so the price in the longrun is simply not something that should enter the equation. Whether you can afford to buy them right now though - that is only a question you can answer. No doubt most of us just don't have that kind of cash laying around to be dropped on a couple of chunks of 300M steel, but it is justifiable... perhaps not to the missus though.
    You will need some maxidrive flanges to suit the ashcroft cv - depending on which one you're using.
    I know what you're thinking. the county CV's are the strongest (allegedly) cv LR make. BUT you're still going to pay for them, because the aftermarket ones are not as strong as gen u whine ones, something I have on very good authority and witnessed/experienced first hand.
    Then there's the shrink ring 'antiburst' method. Waste of time and money. All it means is that when they do go (and they will) the metal will simply explode into hundreds of fragments, rather than just a few. You will take days cleaning it all out of the axle housing.
    No matter which way you look at it, the ashcroft cv is worth dropping the $$$$ on.
    I don't like the 'gouge' on the price though. It's a pity noone else is making them - like RCV for example.
    Roads?.. Where we're going, we don't need roads...
    MY92 RRC 3.9 Ardennes Green
    MY93 RRC LSE 300tdi/R380/LT230 British Racing Green
    MY99 D2 V8 Kinversand
    Oct 2014
    My preference is for early Rangie cvs as they work well and 9 times out of ten the Rangie outer mushroom flange breaks. Repair done without even removing wheel.
    1976 LR 90 Hybrid GONE
    1985 RRC chev GONE
    1997 D1 V8 GONE
    1973 RRC Gone
    1980'RRC Build in progress GOING
    Disco wrecking 93 & 94
    1993 RRC LSE
