Results 1 to 10 of 13
Thread: Spare wheel winder blank - Long range tank
    Oct 2015
    Hi all, I recently had a long range tank fitted to my D4 and obviously the wheel winder was removed. When I had a look under the interior winder cap I notice that I could see the tank, so just a hole where the winder was . I'm interested to know how this has been treated for others with long range tanks.
    I asked the installer if it was correct and they said this is normal. I assume dust will enter here under the interior carpet with just the rubber cap to stop it from entering the cabin.
    Put the cap back on.
    Aug 2010
    Sikaflex the cap down too for added security.
    2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
    Jul 2013
    mine dosent let any dust in
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
    Williams West Aust
    Quote Originally Posted by shanegtr View Post
    With no cap,a window open on a gravel road I reckon it would.Then again who drives on a dusty gravel road with the windows open???? Not me
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Oct 2015
    I really just want to know if everyone's tank is fitted without a blank plate over the winder hole. If that's the way it is done then I guess that is fair enough. I understand that if I have the windows up the cabin pressure will prevent dust ingress (though I will find out when I reach corner country).
    That said, it is counter intuitive to me to remove the winder and leave a hole so I reckon I'll be fitting some kind of cover myself.
    Williams West Aust
    Quote Originally Posted by Morover View Post
    A good reason to seal it would be forced water into the cab in creek crossings or deep puddles at speed.
    Andrew
    Never thought of it, but have done plenty of dirt roads and deep creek crossings and not had any issues. Now I will have to check.
    Oct 2015
    Andrew
    Also heading to the cape so there is a very real chance of that. Not likely unless I'm stopped but you never know.
    The rubber access cap inside the vehicle - just smear some silicone around it and put it in place - it's a grommet of sorts..
