Results 1 to 10 of 26
Thread: Single under-dash power source for aftermarket accessories
    Jan 2009
    Has anyone created a single 12V power supply "bus" under the dash, fed with a single wire from either the main or aux second battery via the firewall grommet to which you can wire all the aftermarket accessories? It may or may not also include fuses for each circuit. For starters I need to power LLAMS, UHF, Redarc TowPro and a TPMS.
    I did all this on the old D3 but ended up with wires everywhere and think there has to be a better, neater way on the new D4.
    There is also the issue of whether to power from the main or aux batteries or from an ignition source.
    Llams is self powered
    Redarc should be wired direct for safety
    Tpms should be switched (use aux socket as pick up)
    UHF depending on your preference would be the only one to consider - I would go direct to main battery to reduce noise.
    Sep 2011
    Minyama
    The drivers side accessory socket (Cigar lighter) is a good accessory feed. The passenger side is separately fused but also feeds the rear of the centre console and the outlet in the cargo area.
    An experienced 4wder advised me to ensure the UHF is powered directly and not through ignition for two reasons.
    - if you are at a campsite and expecting friends to join you you can leave the ignition off and the UHF on to hear approaching friends and guide them in to you.
    - if you are the driver and have the keys in your pocket and fall off a cliff it allows your passengers to get on the radio and call for help even if hey don't have the keys.
    I took his advice and while (knock on wood) I haven't needed it for the second reason, I often use it for the first reason.
    Brisbane,some of the time.
    Quote Originally Posted by AnD3rew View Post
    And on a D4,there is no accessories setting for the ignition.
    Which at times can be a PITA.
    Mar 2015
    Isn't pushing the start button without touching the brake the same as accessories?
    Sep 2013
    No that gets you ignition on - all the dash is lit up
    Williams West Aust
    Even so,its pretty limited how long the ECU will let you use the acc function.The D4 is pretty power hungry it will either time you out or shut you down due to low power stored.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Williams West Aust
    You can also press the wireless button and get the juke box happening after pressing the stop button,but it is timed and power available controled by the ECU.
    Andrew
    Sep 2011
    Minyama
    The "Power Saver" relays (R1 and R3 behind the glovebox) that control the console outlets can be easily bridged with a fused jumper with spade connectors on each end. There is a thread on this way back somewhere. This will give you direct battery feed but run the risk of drawing down the battery if the devices are left on.
