Results 1 to 10 of 12
Thread: LPG Question
    Perth WA
    LPG Question
    Hi All
    Purchased a 1992 RRC Vogue with 3.9 V8
    It on Gas and petrol and surprisingly both work .....most of the time.
    I've had two instances where running on gas the car purring along beautifully and then out of the blue starts to splutter misfire and almost died ....I nursed it home on gas the first occasion.
    Week or so on the 2nd instance running on gas, this time switched it to petrol and she started running smoothly again all the way home. Switched it back to gas when I got home took it for a spin around block nothing .....
    All been well till yesterday when I filled her up and on the way home the engine didn't seem right almost if she wanted to do the same ?. but didn't as I wasn't far from home.
    I've only had car for a month?. gas unit installed in 2008 and I don't know its service history.
    Can anyone advise experiences with gas and if unit needs service, what's involved and possible cost.
    At $39.00c to fill tank I'm interested to see what mileage she gets from full tank ?.fuel injected seems very economical when you come from a 3.5 with untuned std strombergs although I'm not sure if economical and rover V8 can be used in same sentence
    Other than that I'm enjoining the Vogue experience with 4 doors while the 2 door RRC's on blocks awaiting engine.
    Baggy
    G `day ,
    possibly something to do with the coolant .
    Next time it does it lift the bonnet and carefully feel the converter .
    If it`s cold or has frost on it the cause is most likely coolant flow ETC .
    In the mean time when it`s running ok , whether on gas or petrol carefully feel the converter when at running temp and it will be as hot as the coolant in the radiator .
    This will give you a gauge as to what is right and also help eliminate the coolant as a cause .
    There is no need to actually touch the converter when it is hot the radiated heat will be obvious .
    St Helena,Melbourne
    1.13 MB
    Does sound like converter freezer or possibly wax deposits from the gas are gunking up the springs in the converter.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    like they said, x 3
    Feb 2015
    Possibly gunk due butadiene see:
    Gunk in LPG
    Perth WA
    LPG Question
    Thanks everyone,
    I'll check freezing of converter as a source of the problem.
    Had radiator serviced as it was leaking
    The radiator guy I use says it was 70% blocked and i reinstalled it on Wednesday.
    Did refill it as per Pedro the Swift suggestion in the "Good Oil" but understand Rover's are notorious for air locks.... though I did follow the instructions carefully.
    Interested in checking out butidiene gunk as a possible source if converter is nice and hot and how you remove it..
    Also I've had someone at work say he removed his gas conversion from his vehicle
    As every year or so you'd hear of a person killed when gas leaked and caused someone to be incinerated
    What's everyone's veiws ......are the safe and has anyone had or heard of bad experiences.
    Baggy
    May 2003
    On The Road
    Of course they are safe,,
    it would need to be a very large accident for the LPG to become involved,, and by then you wouldnt know about it anyway.
    oh and the stuff in The Good Oil is not mine,,
    I'm just the old custodian, waiting for the next runner to take up the baton.
    Crafers West South Australia
    Do yourself a favour and take it to a LPG installer for a health check. LPG is perfectly safe when well maintained. If you don't have a single clue as to what's happening with the system it may pay you to find some who does have a clue. It is actually illegal for a home handyman to work on his own LPG system, because beginners tend to make stupid mistakes. Please don't become one of the emergency services customers because you've attempted repairs without a good idea of what you're doing. And a few good pictures of said LPG conversion may help with some targeted help from the forum. There are numerous different brands of LPG system available, you could have any one of 20 different brands on your vehicle.
    Perth WA
    Guard LPG Question
    Hi bee utey
    Understand that there are some things you shouldn't touch and I have no intentions
    starting now.
    I'll take a few photos and post it for those more knowledgeable and identify system I have.
    There's a few things I can do in the meantime such as replace spark plugs .... I'll see what she's currently running.
    I'll look at booking in auto gas for a service ...... does anyone in Perth have any recommendations for LPG servicer.
    Baggy
    Perth WA
    LPG Question
    Hi Pedro_The_Swift
    Appreciate your maintenance of the "Good Oil" as it is such a valuable
    resource for all AULRO users.
    Baggy
