Results 1 to 10 of 11
Thread: Overnight D4 / van suspension settings
    Hobart D1 Sydney D4
    Hi
    Interested in what everybody does with their caravans when overnighting and don't wish to disconnect from the from the D4 ie. early start etc.
    My concern is if you leave the van connected, will this put undue pressure on the air suspension system as it try's to self level overnight.
    I currently simply disconnect the van coupling but leave the wiring / chains etc attached.
    Brisbane,some of the time.
    Wouldn't have thought so,wouldn't be much different from leaving a fully loaded vehicle sit overnight.
    It (D4) only levels down (exhausts air).
    Biggest risk it induces is stressing stabilisers on the van if you use them.
    For quick over nighters we leave ours connected..
    Williams West Aust
    Winding the jockey wheel once the van is leveled would stop the vehicle trying to do anything wouldnt it????
    How about the lock function where you raise/lower??? Does that lock it at its current height???
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Feb 2009
    Mt Barker, SA
    Quote Originally Posted by mikel View Post
    Hi
    As Andrew says - just put the jockey wheel on or swing it down if thats the type you have and wind it to the ground. Works on our RRS.
    May 2010
    Southern Sydney
    We raise or lower the suspension until the van is level. Then we just leave it. We have done that for years without a problem.
    I would caution putting the jockey wheel on to take some weight as then if the D4 does decide to lower the suspension the the weight of the caravan and rear of the car can end up on the jockey wheel. This may damage your jockey wheel as it will overload it. Ive done this once while unhiitching.
    NSW SW Slopes
    Adjust car height to level the van then lower the rear stabilisers to ensure it stays still.
    NSW SW Slopes
    Only locks at access height to allow faster under-ground car-park travel.
    Mar 2011
    Cairns
    I find this just one of the really great features in the car and have done it countless times. In off road areas having the ability to select between the 3 heights means i can get the camper trailer level on that axis. A couple of shovel scoops sorts out the relevant wheel on the left/right situation before hand.
    Only 110 kg ball weight when fully loaded so hardly excessive for the carrying capability of the car.
    Jan 2010
    See previous post on this topic. With LLams and a couple of pieces of wood we can get the van level for overnight in some pretty uneven spots where others don't go. Car does not move overnight. I think the trailer being plugged in has something to do with it. We have done this for over 5 years now.
    Gerry
    http://www.aulro.com/afvb/d3-d4-rrs/...tch-night.html
