According to another forum, it is just a matter of plugging in the connectors and away you go (about 1 hours work they say). Apparently it is common for people to leave their sunroof open, allowing rain to destroy the TR panel.
Does anyone know if the Terrain Response panel in a D3 can be swapped with one from another vehicle without having to use diagnostics to program it to the vehicle? The raise/lower switch is broken.
- Justin
Selling soon - MY10 D4 3.0 TDV6 SE with E-Diff & LLAMS, 265/65R18 Maxxis Razr A/T
Moved into MY12 L322 4.4 TDV8 Autobiography
VK2HFJ
It transpires that the switch is not broken but that the panel got rained on via the sunroof and now the lower function doesn't work.
This thread on Disco3UK may help
DISCO3.CO.UK - View topic - Suspension raising lowering switch fix
Peter
Thanks Peter. I've sent the D3 owner the link.
Amazing timing! That Disco3 thread is from 3 days ago.
And just for reference relating to Graeme's original question on another linked Disco3 thread, the following comment from someone:
"Local dealer said you can't buy secondhand as the board is VIN locked so would show up errors"
Not confirmation but would warrant further investigation if the board was the problem.
Link to my D4 Build Thread
D3 2005 V8 Petrol
And then this thread on another board states otherwise
Terrain Response Assembly Unit Install - Land Rover and Range Rover Forums
Edit - Sorry, not really - just stated he bought a brand new one and fitted it with no issues
- Justin
VK2HFJ
