Results 1 to 3 of 3
Thread: New member - 2002 Discovery 2 TD5 Auto
    samp100 Guest
    Hello,
    I've just purchased a Discovery 2 TD5 automatic of a grey nomad in exceptional condition. Only 118,000 kms on the clock, service history and 1 owner from new! It's completely bog standard and drives like new and only has a small clunk underneath when cornering (body loading), so I'm hoping it's just a bush or bushes gone. No noises when in a straight line, accelerating or braking.
    When she reaches 120,000kms my plan is to give here a thorough service:-
    Including all filters (Air, oils, fuel)
    Transmission filter replacement.
    Check the timing chain pulley bolt and loctite it back in.
    EGR removal with a kit.
    Fit new cooling hoses.
    Check brakes, suspension etc
    Grease driveline.
    Is there anything else you would recommend with regards to preventative maintenance?
    I was going to buy genuine filters from Land rover unless you can recommend another source?
    Great forum with a wealth of information : )
    Avoca Beach
    If its anything like mine when I bought it with 134Kk on it there are a few more items to check.
    1 engine mounts. Mine were gone with no off road
    2 Fuel Pressure regulator. You will be lucky if it doesn't leak.
    3 fuel cooler. This will probably be leaking water also. new oring kit will fix
    4 make sure to replace the "hidden hose" down behind the turbo
    5 My camshaft plug was leaking and took out the alternator
    6 idler pulleys. an idea to replace
    7 accessory drive belt. again replace
    8 inspect Injector loom for oil in ECU plug. replace if oily.
    9 EGR . I haven't removed mine , just cleaned with a Gurni.
    10 clean intercooler and check hoses
    The bolt you replace is for the oil pump.
    Regards Philip A
    Jun 2013
    Augusta WA
    Welcome!
    I'm in Margaret River not far away if you ever need advice, There are not many like that with low k's sounds like a good buy.
    Nick
