Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: Accessories
    Tangambalanga
    Accessories
    Couple of questions on accessories for the D4 if I may.
    Does anyone have the original RAI here in Melb that I can have a look at? I'm afraid I don't like the look of the Safari unit and would prefer the original. I know it's not waterproof, but I'm sure this can be fixed from what I've read on here, and have discussed this with both LR and OL, it seems I "may" be able to get it delt with at the dealer (?).
    Another question,, with a second tank fitted, does anybody know if it's possible to change the "total litre" value in the computer to allow for this? Which means if you fill both tanks (this is the gravity fed unit) it would give the fuel total of approx 160lts so the car can work out how far you have to travel on that instead of the 70lts.
    Hope that makes sense. I generally always fill my tank to the top unless I'm in a hurry for work or something, so I'd prefer this option, but I may also see what can be done about having a secondary gauge fitted.
    Mar 2007
    Kalgoorlie WA
    Quote Originally Posted by Chops View Post
    I asked about this some time ago and was told that it can't be done.
    You soon get used to having the fuel gauge work on only the main tank though - it has never bothered me. I just drive until the gauge starts to move from "full" and know that I have roughly 80 litres remaining from then, which is still enough range to get you pretty much anywhere. Sometimes I set one of the trip meters to zero when I fill up - range can be anywhere between 900 - 1000km on mine before the fuel gauge starts to move.
    Best run I ever did with both tanks was from Ceduna to Port Augusta - but had a good stiff tail wind all the way across the paddock that trip.
    I have found that roof rack loading and the head winds that you usually encounter across the paddock (by Murphy's law) will usually reduce that range by quite a bit - and my normal fuelling stops are top-up at Norseman and fill at Ceduna.
    Cheers .........
    BMKAL
    Western Victoria
    The absolute, must have accessory you need that should be standard equipment in a D4.
    Bring it to Winter Wombat.
    Mar 2007
    Kalgoorlie WA
    A nice compact unit like this works well in the Disco. Fits nicely in one of the cup holders ....................
    The ones that they lug around in the Defenders are more flexible in what they can do, but you have to pull over and get out of the vehicle to make your coffee. They're a bugger in the rain.
    Some people I know even have a microwave fitted in the back of their Defender. Don't think I'd recommend this in a D4.
    Cheers .........
    BMKAL
    LRD414's Avatar
    Oct 2014
    This old thread has some good details regarding sealing the inlet piping:
    http://www.aulro.com/afvb/d3-d4-rrs/...ctor-pipe.html
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Tangambalanga
    So, does anyone have an original RIA, (Land Rover accessory), that I can have a look at please?
    Oct 2003
    Montrose, Vic.
    Quote Originally Posted by Mick_Marsh View Post
    Nice piece of research Mick..... I see you found a unit with Loire Blue lighting
    Mark
    2003 D2a TD5...gone...
    2000 D2 V8...gone...
    https://bymark.photography
    Tangambalanga
    I'm gunna brain you two buggers :P
    I watched a flick with a D4 that had the LR snorkel, I think this is the way I'll go. I quite like it.
    Are you nearly ready for a run Mark Its only ohhh about 2.5 months away yet
    I'm booked in for one of Gordons weekends on learning how to drive this beast,,,, cant wait, so many electrical things to learn.
    Oct 2003
    Montrose, Vic.
    It will be worth the wait Marcus
    I can't help you with the air intake.... as mine is Safari.... and my long range tank isn't gravity feed either :P
    But yell out if you have any other queries I may be able to answer..
    Mark
    Williams West Aust
    Ive looked at both the Safari and Genuine on parked vehicles.Personally I like the safari better.
    I think its what I will end up with.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
