Results 1 to 8 of 8
Thread: Externalt antenna
    Wodonga
    Externalt antenna
    I have just orderd a GPS unit, Magellen explorer. Can any one tell me if I NEED an external antenna?
    I was told at the shop it was a waste of money. Is this true?
    I have a Defender
    May 2002
    Heathcote (in "The Shire")
    From my experience with Garmin units an external antenna in a defender is almost essential.
    The GPS needs a good view of the sky to allow it to pick up the maximum satellites from all around. Satellite geometry has a big effect on accuracy. I have found that without an external aerial then you won't get good signal from any satellites behind you due to the almost vertical windsceen coupled with the roof.
    Bushie
    Warburton, Victoria
    Disco's you can get away with it, But Defenders nope.....
    Get and external antenna, Cheap and they make a big difference.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    external antenna is a must have IMHO
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Maleny, Queensland
    GPS Antenna Mounting Suggestion
    With a Defender - definitely. The windscreen is too steep for the unit to pick up enough satellites from the dash. A nifty way to install an external antenna on a Defender permanently is to house it within your air snorkel (assuming you have one). The antenna is safe from weather and theiving hands and you can run the cable into the engine bay through the air pipe and then pop it out and through the firewall to the dash. The plastic snorkel then also means the antenna has a good, unobstructed view of the sky.
    Incidentally, a friend of mine who is involved in manufacturing a GPS car minder system suggested that the entire aluminium roof of a Landrover should make a good antenna if you could wire it up correctly. Don't know whether this is likely, but shouldn't be too hard to test out.
    Wodonga
    Thanks,
    I did try without but it could only get a fix on one or at the best two satilites. As everyone said it is a definte must have.
    Thaks for the input [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    Wodonga
    Tried today the same exercise. Found and had a fix on at least 6 satelites. The best I had was 13 without an antenna. I still have ordered an external antenna though.
    Melbourne, mostly
    The answer is "it depends". Specifically, the answer is a combination of:
    - receiver antenna performance
    - where you mount it in the vehicle
    - where you drive it
    If you spend lot of time in the High Country (hills, trees etc) an antenna is a good idea. If you're an outback tourist you probably won't need one.
    Try without and if you find you need it, get it.
