Hi Tom. In my opinion, don't play with 1/2" sockets. Pop into your local tool store (or those dodgy trade stands at Ag shows), and buy yourself 1x 1 1/16" (or 27mm) 3/4 drive socket (the deepest one you can find.. Have one of your wheel step studs in your pocket when looking for the socket! ), 1 x short 3/4" extension bar (you need the shortest one which is approx 4" long), and 1 x Tee bar. All wheel nuts should be able to be undone with a standard 3/4 drive t bar. Anything longer and they're too tight. Also remember the three nuts that hold the step rings on the front wheels should be put on with the flat face to the step and the taper facing out. Many fit them and force the taper into the thin plate wondering why the wheel step deforms! If there's an option of a deep 3/4 drive 1 1/16" socket, grab it as its handy to get over the step support studs.
				1995 Mercedes 1222A 4x4
1969 (Now know! Thanks Diana!!) Ser 2 Tdi SWB
1991 VW Citi Golf Cti (soon to be Tdi)
'When there's smoke, there's plenty of poke!!'
'The more the smoke, the more the poke!!'
