Results 1 to 4 of 4
Thread: Stainless steel Linings
    Oct 2014
    Northern NSW.Australia
    Who would you use to add stainless steel sleeves to series brake cylinders, Northern NSW/ SE Qld.
    Thanks.
    whitehillbilly
    A while since I did this - just took them to them to my local brake specialist, and they sent them off, got them back in about a week from memory. I suspect there may be only one specialist that does them.
    Brisbane,Qld.
    I have had good service from BHSS-TBS in Smith St, Capalaba. Had a master cylinder resleeved by another mob here in Brisbane and had to have it redone by BHSS as the sleeve was not aligned properly and it was damaging a seal. They seem to always be busy with both shop work and counter and packaged stuff which is a good sign as well.
    TimJ.
    Gumnut - 1953 Series I 80"
    Poverty - 1958 Series I 88"
    Arnie - 1975 710M Pinzgauer
    Irymple, Victoria, Australia
    Billy SS linings will cost you about twice what you can buy wheel cylinders for, or at least that is what I found down here.
    However regardless of the cost they are a great way to go.
    I have just been working on the clutch hydraulics of my 2A and found that all the hydraulics on it have been SS lined by the previous (original) owner, both master cylinders, slave cylinder, and all wheel cylinders. A big bonus.
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
