Results 1 to 10 of 15
Thread: Cape York in a 89 Rangie
    May 2009
    St Agnes, SA
    Should I? Or shouldn't I?
    If so, what advice can you guys give me regarding set up and gear, etc.. that will see me be successful.
    So far I think the trip is planned for about this time next year.
    I have couple of days in hospital, so making a list will keep me sane.
    Thanks in advance!
    Sent from my Nexus 6P using AULRO mobile app
    '15 Discovery 4 HSE- The family bus and the kids like it!
    '89 RRC- My favorite of the bunch!
    Ex '03 Commodore 'S' ute- 450hp of uncracked 5.7lt and 6 speed manual uteness - Still crying that its gone
    Ex '06 GLXR Triton- *Gone and forgotten*
    Aug 2010
    Sunbury, VIC
    I'd drive mine around Australia no dramas, but you would need to be confident in both your vehicle and your repair skills IMO. I know mine inside out, back to front so I'd be happy with this, but if you've had reliability issues in the past, you'd want to do plenty of trouble free KM before setting out.
    May 2009
    St Agnes, SA
    You have a fair point. I have driven the oodnadatta track ad hoc with only it set up as is and researching tyre pressures the night before, with no problems.
    And considering 90% of the trip is a formed road, I can't foresee any issues, but I guess you won't until you hit the rough stuff.
    I'm fairly confident in the vehicle and all 4 of us are mechanics, so there should be no worries in someone being able to fix things.
    I am also thinking about keeping it all in-car with a roof top tent and all that good fruit.
    Oh and there will be a second vehicle.
    Aug 2012
    Encounter Bay
    We travelled there couple of years ago, no problem. Fuel readily available, enough passing traffic ,a fair amount of bitumen,....enjoy !
    dave
    May 2009
    St Agnes, SA
    What did you do it in? Do you recommend anything in particular to get there and back, or is it not really that special?
    Avoca Beach
    I did it a couple of years ago in my 91towing my camper trailer and doing the Northern OTL.
    I recommend that you have good tyres with at least 75% tread, and know that your shocks and suspension bushes are in good condition. I did a fan on the Northern OTL and had a new one sent to Cooktown to pick up on the way back.
    Unless your RRC is raised , locked and loaded it is not a good idea to try the OTL.
    When I did it the stretch to Coen was by far the worst ( whoops forgot the bit along the ridge after where the Northern track starts) and the Coen RACQ bloke makes a fortune out of fixing broken camper trailers. This is because semis use this bit to get to Weipa, and once a week the Woolworths truck does the trip. I met him when he was south of Coen and even he was crawling along at about 20Kmh. There is a woolies at Weipa to restock which is resupplied once a week, when we were there on a Tuesday.
    I really enjoyed Archer River, and Moreton Telegraph station and swam in the Archer River before seeing the do not swim signs.LOL
    Seisia is great and has a good minimarket supplied from Cairns and Bamaga had a great bakery. Punsand Beach is great to stay at and don't miss the Beaufort and D3 wrecks near Bamaga airport. The Five beaches drive south of Somerset is a great drive but keep away from the mangroves and it can be very soft.
    Regards Philip A
    May 2009
    St Agnes, SA
    That trip sounds the go.
    How long did it take you in total?
    I might have to try and map that out.
    I am in the process off redoing all the suspension bushes and giving the car a good once over. Shocks are 5 years old but still in pretty good condition.
    I am considering putting a air locker in the front and some degree of a LSD or something in the rear(lockright maybe?) But will have to see how the budget holds up after a winch and other gear.
    I also read that it's better to have all terrains as opposed to muddies. How true is this? About that time I should be due for a set of tyres so could be a good opportunity to get the right ones first go.
    So far my 89 is set up as follows:
    2" lift with foam cell shocks
    -25 offset 16x8" rims with kuhmo roadventure MT's
    Steel bull bar (will be set up with winch)
    Steel rear bar with custom spare wheel carrier and two Jerry holders
    Steel roof rack for roof top tent
    GME CB with 6ohm antenna
    Dual battery set up and will extend to a third for the trip
    Rear draws and fridge set up
    Hard wired and plumbed air compressor with air tank
    List goes on for the small stuff.
    Guess I'll just have to get the traction side sorted.
    Brisbane, Queensland
    You won't need the lockers unless you plan on going off the main drag.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Avoca Beach
    IMHO ATs are adequate and remember there are thousands of miles of Bitumen to cover before you get there which with aggressive MTs may drive you mad..
    It took about 10 days actually there plus the time to get there. We spent 3 days at the tip, including a boat trip to Thursday Island from Punsand and the Somerset drive.( 1 night roadhouse, 2 nights Weipa, 1 night Archer, 2 nights Seisea, 3 nights Punsand on the way up AFAIR) Moreton on way back
    I would do it the other way around. I had a rear Maxidrive and front Quaife . The Quaife/Ashcroft/ torque biasing diffs are great IMHO and transparent.
    In any case unless you do the OTL, all of those are unnecessary, and if you do the OTL you will need a winch as you WILL need to winch up Palm Creek and others.
    In any case a petrol RRC is unlikely to make it through Nolans Brook, or for that matter the unnamed creek before , which is where I turned back when there was water up to my crutch for about 100 metres.
    Regards Philip A
    Dec 2014
    FNQ
    Phil is right about Nolans. It's the vehicle-wrecking epicentre of the track. Oh and the idiots who want to try the old gunshot creek drop-in. Stay on the chicken track.
    Easier still, stick to the development rd, no need for huge vehicle upgrades and the road is pretty good north of cooktown anyway. For the first-timer, I'd actually suggest this route, as it affords you some time to go and check out other places, like those mentioned earlier.
    The more I think about it, the more I'd take a 'disposable' td5 if I wanted to do the old tele.
    Logans creek and mistake creek can be a little tricky if the water's up. If you're going in the middle of the dry season, you're also going to encounter the track damage done by those who tried to get through at the end of the wet.
    If you really want some serious adventure, then the maybe old coach rd is worth doing - and taking the creb track north from daintree instead of the bloomfield track - those are quite interesting options. But like everything up north, it's all much nicer in the wet season - you just can't drive through it, thats all
    Oh I forgot to mention crossing the daintree river. There are a couple of ways, but the last time I went up the bloomfield track was washed right out, yet we still managed to get a locked FJ cruiser through it - wasn't too much fun though, and the cairns airport hertz staff had a fair old bit of crap to clean up
    The alternative is the creb and that's a slippery steep bugger, so lockers are probably mandatory, and definitely a winch. And a 50m extension. (Long story)
    All in all, for a first timer, I reckon the scenic route is easier, less stressful if you have passengers who dislike corrugations and large boulders or deep croc infested river crossings. But the old roads are so much more inviting....
    Roads?.. Where we're going, we don't need roads...
    MY92 RRC 3.9 Ardennes Green
    MY93 RRC LSE 300tdi/R380/LT230 British Racing Green
    MY99 D2 V8 Kinversand
