Results 1 to 6 of 6
Thread: Wastegate modulator hose
    Oct 2010
    Caloundra
    Strange one. I've had to replace the bottom hose on the wastegate modulator - common problem I believe.
    But, I'm struggling to find the right size hose. A 4mm home will fit snugly on the bottom pipe of the modulator, but is too small for the barb on the intercooler pipe. A 5mm pipe will go onto the intercooler pipe barb, but is too large for the bottom barb of the modulator.
    Driving me nuts. Is it a special hose, or will I need to get the intercooler pipe right out to fit the 4mm hose on it?
    Pennant Hills, Sydney
    Silicon hose is what I used 4mm will stretch over the slightly larger tail
    disco seriesII mods so far:-bullbar,hyd winch,
    detriot locker,lsd front,C.D.L kit,chipped and bigger intercooler,2" lift,rock sliders, lsd in transfer case, modified auto trans.
    In the event of nuclear war,Disregard this message
    Jan 2011
    Gippsland
    Quote Originally Posted by Pinelli View Post
    I used GATES 5/16" fuel line and TRIDON hose clamps - a failsafe solution.
    onebob
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
    Nov 2014
    Nirvana near Albany W.A.
    Quote Originally Posted by onebob View Post
    onebob
    That's around 8 mm ?.
    I use silicon as well , but you should be able to get the standard 4 mm on if you stick it in very hot water first
    Oct 2010
    Caloundra
    3/16" perhaps?
    Thanks everyone.
    Jan 2011
    Gippsland
    3/16" perhaps?
    Thanks everyone.
    You might be right, me thinks
    onebob
    LROCV member #131
