Results 1 to 10 of 22
Thread: Best $120 I have spent so far
    Kallangur, Brisbane
    My halogen headlights have left me underwhelmed. Not sure about a bullbar at this stage so I needed an interim measure to improve the lighting. Found this:
    32inch 300W Curved Philips Spot Flood LED Work Light BAR SUV Offroad Lamp 30" | eBay 32inch 300W Curved PHILIPS Spot &Flood LED Work Light Bar SUV Offroad Lamp 30"
    Knocked up some brackets that mount behind the front grill & protrude through as per another post somewhere....The curve exactly matches the curve of the grill & the bar does not protrude beyond the bumper.
    For distance, it does not come close to spots but lights up the world for the first 100m more than adequately & completely drowns the halogen lights. I did not notice any difference in radiator temps during the last 1000 km traveled while towing but then it hasn't been above 30deg.
    + 2016 D4 TDV6
    Lekker Best 0 I have spent so far
    Williams West Aust
    Looks good.Something I would like once I get a roof rack.
    Beware the temp gauge,as far as I know its a computer generated thought bubble like the D2.Unless you are using an OBD reader to get the temperature.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Jan 2008
    Lysterfield, VIC
    Hi Milton
    Do you have any pics of the brackets or how you mounted them? I miss my old light bar from my D2 and even though I have xenon they aren't as good as the light bar for closer distances.
    What about vibrations? Does the bar move/vibrate around much? And lastly, where did you mount the light switch?
    Dave.
    Dave.
    Hi.
    96 Disco 1 V8.
    99 Disco 2 TD5.
    LROCV.
    Dec 2009
    Hi Milton - looks great! Thanks for the link! Any pictures available that compare the light outputs of (eg low beam only, low and high beam, low and high and light bar?)
    I fitted mine into the grille,
    Safe Travels
    harry
    Kallangur, Brisbane
    Quote Originally Posted by DI5CO View Post
    Hi Milton
    Dave.
    Sorry, no pics of the brackets. They are "T" shaped & mount to existing holes in the radiator mounting. Once through the grill, I had to make 2 "L" shaped brackets that mount on the first 2 to accommodate the width of the bar. Everything was made from 5mm flat bar. There is a small amount of vibration on corrugations but quite acceptable for me. The switch is called a mouse switch I think & is double sided taped to the dash next to the headlight switch.
    + 2016 D4 TDV6
    Kallangur, Brisbane
    Quote Originally Posted by eddomak View Post
    These pictures do not do the lights justice: I need to find a quiet patch of highway where the difference is more noticeable & I can stop & take photos.
    Low beam:
    High beam, no light bar:
    High beam with light bar:
    + 2016 D4 TDV6
    Dec 2009
    If anyone is interested, the eBay item just went on special to $105.99 today.
    Ean Austral Guest
    Quote Originally Posted by harry View Post
    Gday Harry,
    Can you give us some pointers on how you fitted it like that, that looks awesome and is 1 of the best ideas I have seen for a light bar yet.
    Cheers Ean
