Results 1 to 10 of 19
Thread: TD5 Radiator O.E.M or not ?
    Ean Austral Guest
    Gday All,
    The father in laws TD5 has a leaky radiator , he did well to get it to last this long having towed the palace behind it for a few laps of oz.
    So ,
    Refit a O.E.M or are the after market style ones even better. When I replaced the radiator in mine I went original but never kept the car much longer to see how it went.
    Anybody recently done a change.
    Car is a 2004 auto.
    Cheers Ean
    May 2014
    Put a full alloy in mine td5 2003 due to snapping reservoir bleed hose off lot of little fiddly mucking around things but it fitted not noticed any improvement having it over standard and not had any problems been in for ages but if it cracks splits out bush it can be repaired it was my thought anyway and it tows a cub every were we go never gets hot
    1960 series 2 143001010
    1976 series 3 91331709c
    06 discovery v6
    2014 discovery tdv6
    2010 cub supamatic drover
    Ean Austral Guest
    Seems to be a lot of aftermarket ones available but not many original equipment , that's most likely due to the age of them these days.
    Thanks and Cheers Ean
    Road Stone Guest
    I have been here, and concluded that given such an expensive bit of kit (the engine) relies on this part...OEM it was.
    Cheers, Jerry
    Jun 2008
    McMinns Lagoon NT
    I busted a hose outlet on mine playing around with when I was still in Gove Ean. As far as I can remember I ordered a replacement from Berrimah Radiators.
    That unit is still in it. The vehicle took our camper trailer to the Kimberley in 2015 and also towed a 17' off road van to Brisbane and back last Christmas and it is still going strong.
    PS My memory may not be correct and I may have got it from Karcraft - can't find any paperwork for it.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Ean Austral Guest
    I will just get an OEM job and be done with it , if he still has the car in 12 more years we will worry about the next option.
    MarknDeb Guest
    Gday Ean we replaced ours late last year and I got the all aluminium off eBay from WA and its pretty good, the best thing is if it develops a leak it can be repaired. The only thing I had to do was modify 1 mount on the intercooler so it would fit, you can get from the UK 1 that has a new intercooler with it for another 150 from memory and I should have got that.
    Dec 2008
    Beechboro Perth
    Ean,
    I fitted one from Island 4x4 in Feb 14 and have had no issues with it. I think it was a Nissen brand radiator.
    Radiator Td5 98-02 (OEM) PCC001070G PCC107270G PCC000640G Island 4x4 - Specialists in Land Rover and Range Rover Parts and accessories for all models. UK and worldwide mail order.
    Roger
    Oct 2011
    Fremantle WA
    Quote Originally Posted by MarknDeb View Post
    From WA?
    MarknDeb Guest
    Sorry Gavin and all others it was sent from an eBay dealer in Melbourne, ASI Performance
