Results 1 to 10 of 28
Thread: Your D2 on a Two Post Hoist
    May 2003
    On The Road
    Question Your D2 on a Two Post Hoist
    I've seen mine on a couple (alright, maybe more than a couple) of two posters and while it has never fallen off,, I've never been really happy with the way it sits.
    Is there a LR recommended lifting position?
    How do our wonderful Professional Mechanics lift a D2 on a two post hoist?
    Sep 2010
    Branxton NSW
    Aug 2008
    Perth, WA
    37.36 MB
    I seem to recall the chassis on that ute was rusted out.... Not a nice thing to happen though!
    Tangambalanga
    When I had the D1, I refused to put it on a two post hoist when working on it myself,, much preferred to use the 4 post.
    I've seen the aftermath of the hoist falling over with a car on it, probably not bolted in properly. Mind you, I've seen car run off the end of a 4 poster too,
    Two post IMO was too unstable even with the lighter cars we used to put on it. Sometimes you need to put a fair bit of force on things.
    Not sure exactly where on the car exactly the pads should be placed though.
    Hay Point
    Don't know what you blokes are worried about - I lift my 6x6 on a 4T 2 post hoist. Doesn't look unstable at any time but I do regularly check the bolts holding the pillars to the concrete. Must admit I was a little nervous the first time I lifted it!
    Cheers......Brian
    1985 110 V8 County
    May 2006
    Woolgoolga
    I have a two poster, have had my rangie and old d1 on it many a time, no dramas at all.
    May 2003
    On The Road
    yes Vern,, but where did you lift it from?
    schuy1 Guest
    The local tyre place has a 2 poster. The first time the D2 went on I was a little wary, though the guy said Tojo wagons go on oki. It only went up to clear the ground for the wheel changing. Seemed firm enough for that but as has been said I would prefer a 4 if doing any tugging and pulling on stubborn components, It did have some movement however very slight.
    Forgot to add this https://discoweb.org/forums/showthread.php't=78798 It has some pics in the thread that give an idea where the arm pads go , Oh and a nice scary piccy too
    sheerluck Guest
    The floor??
    Williams West Aust
    Pedro.
    I used the work 2 poster to do all my servicing on my D2,it was never an issue.Always tried wobbling it with the wheels just off the ground.Had the hoists lifting arms about where the front and rear suspension arms met the chassis.
    Yet to try the D4 on there
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
