Results 1 to 8 of 8
Thread: Oil leak, should I be concerned
    Feb 2014
    Having a crawl under my 110 this morning, noticed a leak. Should I be concerned or just think "its a defender"? Its a 2013 and under warranty btw
    Apr 2014
    Blair Athol, Adelaide South Aust.
    Get it fixed under warranty. That what warranty is for. Fix now worry later.
    Cheers Rod
    Sent from my GT-I9507 using AULRO mobile app
    Apr 2007
    Agreed
    Shepp
    Feb 2014
    I guess the dealer is not going to like me.
    I already have a new roof on the way, they are hunting for a squeal coming from the rear between 60-80kph, and have asked them to look at a leak from rear of front diff. Will add this one to the list....
    Simon
    May 2012
    Perth, Northern Suburbs
    Hi Simon,
    I had a squeal type noise around 80km/h. I believe it was the exhaust heat shield vibrating or similar causing the noise. I'm sure it's a common problem.
    others can explain it better I'm sure
    Feb 2014
    BigBlueOne
    Thank you, will ask them about that. First they said brakes and changed pads and disks at my cost but did not cure. They have agreed to refund me.
    They said not the diff as they said it would squeal at all speeds.
    Simon
    Oct 2010
    Adelaide Hills
    I'm guessing that's either intermediate shaft o-ring or input shaft seal leak or both. Get it done under warranty as will be TC out to fix either properly.
    Feb 2014
    Steane
    Sounds like on the plus side then I can get the adaptor shaft checked if the tc has to come out.
    Will pursue the warranty fix
    Cheers all
    Simon
