First check the seal.
Beg borrow or steal a tube of dark lipstick and smear the rubber, close the door and check the imprint on the door to see where if anywhere the seal is not happening. Check the adjustment on the latch.
If that fails don't use the left over lipstick because that is a "bad look" and the colour won't suit you. 8O :wink:
I have heard that inserting either a closed cell foam sealant backing rod (used in construction circles) or the rubber rod, used to fix fly screen into door and window frames, into the rubber will bolster the seal.
Also a liberal application of vaseline on the door rubbers at least in dusty conditions helps. That leads to the question: Does it take in dust?
