My D2 TD5 has almost reach its 250km mark and has only had an oil, air and fuel filter change since I've owned her.
I'm planning on doing a somewhat detailed and thorough service and check including changing of:
auto fluid and filters
engine oil and filters
diff oils
transfer box oil
air filter
greasing of propshafts and joints
Is there anything else that I'm missing here? How does everyone else go about their servicing?
I've done the fuel filter about 8000km ago and believe it shouldn't have to be changed for a while now.
I confidently have a service history up to early 2014 and since then the vehicle has done less than 40,000km.
Cheers!
2000 D2 TD5: Tunit Chipped, EGR Delete, 2" lift, 265s, TJM bullbar, full length roof rack
Build date 11th Oct 2003
LROCV #1410
Page not found.
Here
LROCV #1410
Plus other long term preventative items if not been attended to yet:
Remove and clean alternator and change brushes
Replace starter motor contacts
And if going remote, change fuel pump if it's original
Check usual Td5 items including fuel pressure regulator for leaks, fuel hose rubbing near from top of fuel tank, injection harness for oil where it joins engine harness, harmonic balancer condition.
Also that little coolant hose beside turbo up against engine block, the rubber doughnut on rear drive shaft.
Check your air con hoses where they can rub through on the engine mount, wires along front of the head insulation can break down from the heat off the EGR valve.
Bolts that hold the counter weight behind the park brake drum these come loose, check the mounts too.
disco seriesII mods so far:-bullbar,hyd winch,
detriot locker,lsd front,C.D.L kit,chipped and bigger intercooler,2" lift,rock sliders, lsd in transfer case, modified auto trans.
In the event of nuclear war,Disregard this message
Buy your self a Haynes owners workshop manual. Service routines are laid out in detail.
I’m pretty sure the dinosaurs died out when they stopped gathering food and started having meetings to discuss gathering food
A bookshop is one of the only pieces of evidence we have that people are still thinking
Centrifugal filter?
JayTee
Nullus Anxietus
Cancer is gender blind.
2000 D2 TD5 Auto: Tins
1994 D1 300TDi Manual: Dave
1980 SIII Petrol Tray: Doris
OKApotamus #74
Nanocom, D2 TD5 only.
I downloaded RAVE the Land Rover service-workshop manual. I print out the bits I need. I accidentally printed 840 pages of this at work!!
Get RAVE, from the usual suppliers and also get microcat.
LROCV #1410
I have RAVE, which I use often. Correct me if I'm wrong, but Haynes details the recommended service intervals, eg;
every 6000 miles or 6 months
every 12000 miles or 12 months
every 24000 miles or 2 years, whichever occurs first
every 36000 miles or 3 years, whichever occurs first
every 48000 miles or 4 years, whichever occurs first
every 60000 miles
every 72000 miles
every 96000 miles
every 15 years.
I stick as close as I can to the schedule, and I use RAVE to supplement the Haynes. My D2 has 396000 KM's on the clock, fingers crossed, much more to come.
