tdci fuel sender resistance range
					Have puddled about online but drawn a blank.
It seems the newer 2.4/2.2 tdci defenders still operate the fuel sender/ gauge via a variable resistor style setup. As opposed to some funky CANBUS / ECU system.
But Im struggling to establish the resistance range.
Im putting a second tank under the tray with transfer pump and contemplating putting a sender in it with a switchover relay so when pumping it across to the main tank the dash fuel gauge reads the reserve tank.
So I just need to match the resistance range of the factory unit.
If no one knows I suppose I can pull the factory sender and test it but the easy option would be appreciated
S
