Results 1 to 4 of 4
Thread: 300 tdi front wheel bearing seal.
    Almost finished changing both front wheel bearings and looking for the latest thoughts on setting the seal. Does it sit 4mm below or flush with the fine lip protruding above?
    seems to be a couple of thoughts on dr google. My manual is not specific.
    Thanks in advance.
    Jan 2010
    Perth S/W
    I have been wondering about this myself . Will be looking forward to any replies .
    May 2011
    From UK to Melbourne
    My seal had 3mm written on it but as long as it doesn't protrude past the hub it should be fine.
    G
    Geelong, VIC
    Use the axle drive flange as a tool to knock the seal in. Just drive it in until the flange hits the hub and it will be nice and even and the correct depth.
    I've done mine that way for years since reading it on here (thanks JC).
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
