Results 1 to 2 of 2
Thread: Heater hose orientation
    Oct 2007
    Brisbane West
    Hi all. As I read Rave the v8 cooling system diagram shows the passenger side pipe from the heater matrix going to the top of the water pump. On mine that results in the pipes crossing over between the heater matrix and the steel Siamese pipes. Routing it that way means no waterfall sound which is good and makes sense because the water is filling up from the bottom of the matrix. Can I get some replies as to orientation on stock vehicles just to make sure I am reading things correctly? Cheers
    May 2003
    On The Road
    yea, from what I can see the water goes into the matrix at the bottom,,
