Thread: L322 2003 HSE ignition lock (not the normal issue)
    Racer014 Guest
    Hi folks, New to the forum so here go's.
    I've got a 2003 L322 diesel, fantastic carbut I've had it 5 days and we're stuck.... (qualified mechanic, very auto-electrically minded)
    (it really is fantastic, love driving it)
    The ignition key wont turn. So I've been online and searched the forums for the usual faults, most suggest removing fuse #18 for 30 seconds and dropping the battery lead off etc, no such luck. Issue still remains and key wont move more then half way to position 1. Tried dropping the battery cables off, reconnected, no luck. The only thing I've touched is the key fob, I removed it and replaced the buttons with a new set. Otherwise I havn't changed anything.
    I have since lubricated the solenoid valve inside the steering lock barrel. no change. The biggest difference I can tell to other peoples issues is mine doesn't sound like its trying to unlock when inserting the key, nothing at all.
    Any help would be greatly appreciated. I just took my other car off the road so I'm suck without wheels.....
    Dan
    Apr 2007
    South Australia
    theres a tiny little rfid like radio tag type device inside the key fob which the car is looking for as a security measure, and if it fell out and wasn't put back in, the car security system wont see it and wont unlock.
    The RFID has an encrypted code is what makes the remote unique.
    I believe its the little black wedge in the picture:
    2007/2002/2000/1994/1993/1988/1987/1985/1984/1981/1979/1973 Range Rover 1986 Wadham Stringer
    and a Nissan Cube............
    South Australia.
    Also join this forum fullfatrr.com - Index and ask there.
    They are an L322/L405 only forum.
    See also [ame]http://www.fullfatrr.com/forum/topic14930.html[/ame] - on the second page of that thread is a link to this: [ame]http://www.blackbox-solutions.com/photos/L322lock.pdf[/ame]
    Racer014 Guest
    Thank you both so much for your help, turned out that little black chip had fallen out while changing the buttons, she's up and running and as good as new! Now to remove the egr + cooler. videos before and after (as well as rough 0-100 times from My gps data logger )
    Good stuff Racer and well done John (jsp).
