Results 1 to 10 of 14
Thread: Tow hitch bolt spinning
    Sep 2010
    Perth WA
    I went to remove my tow hitch on the weekend to fit an APT fuel tank guard and one of the 4 bolts in rear cross member was loose and spinning. I haven't been able to get it out and have tried a variety of methods. I'm going to call the dealer tomorrow as the vehicle is still under warranty and they fitted the towbar.
    Has anyone else had this issue and is there an easy fix?
    Western Victoria
    I have used one of these with success.
    I used it to hold the neck of the ball whilst using a ring spanner on the nut.
    May 2014
    Tamworth NSW
    I think he means one of the 4 bolts below (Pics courtesy of John3950, posted in the puma thread. Click pic for sauce post)
    -Mitch
    'El Burro' 2012 Defender 90.
    May 2014
    Tamworth NSW
    As for the fix... have you tried a spanner in the hole?
    If you have means to get a drill or rattle gun on the bolt, sometimes the speed of the gun can undo the bolt (unless it's really loose).
    -Mitch
    Quote Originally Posted by Toxic_Avenger View Post
    May 2014
    Tamworth NSW
    COME IN SPINNER!!!
    I knew someone would pick that up.
    It's colloquial for 'source'. Link.
    -Mitch
    Sep 2010
    Perth WA
    The nuts appear to be in a sealed box unit so I can't get at the other side.
    May 2014
    Tamworth NSW
    You know the answer:
    -Mitch
    Sep 2010
    Perth WA
    Dropped into the dealer on the way home today. They're going to send it off to LRA for a warranty claim as they fitted the towbar.
    The solution appears to be either drop the fuel tank and cut a hole in the back of the cross member to remove the existing nut or replace the cross member.
    Oct 2007
    Wantabadgery, N.S.W.
    Drill the head off the bolt. Centre punch dead centre first.
    Don.
