Got the battery polarity correct?
 Fossicker
						Supporter
						Fossicker
						SupporterG'day gents, need some help. I've changed the battery (2032) on the smart key for the D4 but when I got back into the car and hit the ignition / start button I got the message "Smart Key Not Found. Refer to Manual". I couldn't find anything in the manual about this, anyone had a similar problem and managed to overcome it? I even put the old battery back - which was low - but even that wasn't recognised.
2024 RRS on the road
2011 D4 3.0 in the drive way
1999 D2 V8, in heaven
1984 RRC, in hell
Lock, wait, unlock. Try to start.
 Wizard
						Subscriber
						Wizard
						SubscriberYou held it up against the steering column?
They do make me wonder sometimes. My wife was getting that message with her key so I swapped her for my key, thinking I'd change the battery when necessary, but I've not had any trouble at all with hers.
Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
Then 2010 D4 3.0 HSE 'James'
Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
Then 2010 D4 TDV6 'Jumbo' w traxide DBS
First love 2002 D2 TD5 'Disco Stu'
As the D4 transponder battery change is a non event, i normally call into the battery place on a road test and change it while in the car park.
The only two things I can think:
*As mentioned, check the battery is in correct.
*I've had a "new" battery that was already low (well low enough for it not to work, hence why I change out the battery while at the battery place).
Daz
Daz
 Fossicker
						Supporter
						Fossicker
						Supporter Master
						Subscriber
						Master
						SubscriberI know it sounds silly, but have you checked the new battery voltage?
- Justin
Selling soon - MY10 D4 3.0 TDV6 SE with E-Diff & LLAMS, 265/65R18 Maxxis Razr A/T
Moved into MY12 L322 4.4 TDV8 Autobiography
VK2HFJ
Do you have the other key for the vehicle so you can give it a try?
Last time mine came up with that message it needed some kind of software update.
 Fossicker
						Supporter
						Fossicker
						SupporterIt seems as though the 'new' battery (out of a packet) wasn't so 'new' after all. Bought another 'new' battery this morning and, bingo, all's good with the world again.
Yeah, my original battery lasted 4 years. My last 'new' battery lasted all of 10 months.
1984 RRC, in hell
