Thread: Suspect TD6 injector wiring harness
    Feb 2014
    so, I noticed this morning a very slight vibration from my usually silky smooth td6. Immediately im suspecting the injector harness as the fault.
    I turned on the IID tool and found the cyl 1 and 2 were not being normal in the fuel rates at idle, then #2 began to flick between normal and abnormal depending on direction i was turning and bumps etc.
    anyone had experience with replacing (I have exposed previously and know it wont be difficult) and where was their source for a new harness?
    Pic shows abnormal values...slightly blurry, my bad
    Feb 2014
    After shopping around on the net, i didnt want to pay over $250 for a used let alone new harness...obviously. I started at looking at getting plug etc and making one.
    I decided to see what the ULR could get one in for, i have had luck in the past with some bits being cheap and some not so.
    for a total price including next day delivery to my house....$97
    check back tomorrow for more updates.
    Apr 2007
    South Australia
    I have done two now.
    they are fairly cheap - last one I bought was $75!
    quick and easy to fit. Mine have gone brittle around the plugs. Runs like a bucket of bolts when they go bad.
    2007/2002/2000/1994/1993/1988/1987/1985/1984/1981/1979/1973 Range Rover 1986 Wadham Stringer
    and a Nissan Cube............
    South Australia.
    Feb 2014
    Hmm, i put it in this morning, hey presto all good....for about 150kms...
    I have read some other people have had bad ones out of the box after short periods, ill have to look into this more tho.
    Feb 2014
    All sorted!
    Replace #1 injector with a very very cheap BMW one off fleebay
    I was expecting this "flow tested" one to be a waste of money...but 3 for $80, it was worth a crack.
    Also, bmw ones fit no problem as expected.
    Kingston, Tassie, OZ.
    How many kms?
    Jc
    Feb 2014
    How many kms?
    Jc
    up to 230k now! I pack em on, started at 150
