The battery could have a broken internal connection causing intermittent low voltage.  However these alternators fail because the Zener/avalanche diodes deteriorate with usage whereby their trigger voltage that shuts-down (short circuits) excessive voltage to protect the vehicle's electronics gradually drops from the original 30V to normal charging voltage.  Hence a low charging voltage doesn't trigger the reverse current flow but when the voltage rises just a little more, the diode that has deteriorated the most short-circuits.
On a different tact, there is a noise suppression capacitor attached to the outside of the gearbox that is known to fail short-circuit thereby drawing excessive current.
Edit: The reverse-trigger voltage of the diodes is affected by heat, thereby altering the voltage at which the short-circuit occurs and possibly causing more than just a single diode to short-circuit.
A single short-circuiting diode (only 1 phase affected) may be overpowered by the other 2 phases still functioning properly allowing voltage to be maintained with the engine running but the battery will soon be drained by the short-circuiting diode once the engine is stopped.
				MY21.5 L405 D350 Vogue SE with 19s.  Produce LLAMS for LR/RR, Jeep GC/Dodge Ram
