Results 1 to 10 of 11
Thread: air compressor - running on .........then "PUFF"
    Queensland
    Gents, my air compressor is staying on much longer than normal and finishing with a large "PUFF". Possible Diagnosis??
    L405, Vogue SE, 4.4SDV8, 8 speed, Rear e-diff
    NSW SW Slopes
    There is always a release of the pressure from the line to the reservoir, the front and the rear valve blocks as soon as the compressor stops, presumably to make it easier to start next time.
    Running longer could be a sticky relay (the compressor relay's contacts have a hard life) or the compressor getting weak or the reservoir was depleted significantly last use.
    Queensland
    Thanks Graeme - will keep an eye on it this week.
    Brisbane, Queensland
    I can never hear my compressor running. Maybe too much right foot is drowning the compressor noise.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Feb 2014
    do you regularly use the access height? Sounds like a tired compressor
    Queensland
    Yes, I do - alot - has been good last couple of days but keeping an eye on it.
    Feb 2014
    simply put, you wore the compressor out by raising and lowering a lot. if your handy with a spanner, rebuild kits are not too dear off ebay. not difficult to fit either.
    Queensland
    Thanks - will look to do that; at least its easy to get to
    NSW SW Slopes
    A quite different Hitachi compressor superseded the earlier version Hitachi starting with MY11 so the rebuilt kits for the earlier versions might not be suitable. Then an AMK compressor was fitted starting around May 11 but reverted to the Hitachi about the time and perhaps co-incidental with MY12 production start. However an AMK upgrade kit now supersedes the Hitachi.
    Aug 2010
    Sunbury, VIC
    Yes, it won't be the common Wabco kit you're after, you'll need to find out what compressor you're running first. Probably the Hitachi - kits are available for these too very cheaply.
