I pulled apart the centre trim today to have a hunt around for a constant 12v supply so that I could tap into it to take power to run my uhf. The only plug that I could find had 12v constant was the plug that goes into the hand brake lever.
Anyone know if any errors would be caused by by taking power from this source or would there be any other issues?
Get a piggy back fuse and hook into the fuse box behind the glove box,you then get a choice of live all the time or ignition fed.You need the mini size.
About to order some myself.
Narva ADD A Circuit Fuse TAP Piggy Back Standard Blade Fuse Style Twin Pack | eBay
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
- Justin
Selling soon - MY10 D4 3.0 TDV6 SE with E-Diff & LLAMS, 265/65R18 Maxxis Razr A/T
Moved into MY12 L322 4.4 TDV8 Autobiography
VK2HFJ
They can only go one way.The original circuit is protected by the main fuse,the tail that comes off the unit is protected by the additional fuse.I have mi Icom wired that way.
Im going to hardwire usb plugs and a ciggy lighter into the Kuda mount that has just left the good ole US of A
Will be able to fit a tablet for nav,a TOMTOM and a Blackvue crash cam without a tangle of wires
Andrew
Ahh right, as in the tail won't fit round the other way? I haven't had to use any in the D4 yet, but I have used the larger ones before in a situation where the tail fit both directions, so if you put it in back to front, the tail runs through both fuses in series, therefore your original circuit fuse is on both circuits.
- Justin
VK2HFJ
Have a look at the link.They are bloody great,saves hacking into wiring.
I got a double usb and a cigy lighter with double usb so 4x2.5 amp USB plus the ACC outlet.I got 2 switches too.Thinking of wiring 1 bank to permanent live,1 to ACC with a switch on each circuit so I can simply switch them off when the vehicle isnt being used.That is to be decided yet,may just run the lot as permanet live with 1 switch.
Andrew
MY23 D300 SE Silicon Silver
2014 MY15 D4 3.0 SDV6 HSE (Sold)
Complete Campsites Exodus 14 Camper Trailer
2015 Triumph Tiger XRT
