I'm looking forward to do this one day as well.
Just nuts and bolts hey
 Master
						Master
						Hey guys.
I've got a puma 130 with a steel tray, aluminium canopy on 33's with 120k on the clock. The gearbox output shaft has been in the back of my mind for a bit and i was going to chuck one ashcrofts improved versions into it.
How harder job is it to do? Is it just pull the transfer case off and replace the output shaft with the gearbox in situ or is there more to the job that I'm missing?
Cheers in advance.
Mick
 Master
						Master
I paid the mechanic to do it, but from what they said they just took off the transfer case, and that the Ashcroft was was superior to the standard.
Richard
There's a how to do it workshop article in the latest LROI magazine.
Sent from my SM-G900I using AULRO mobile app
 Master
						Master
						Thanks guys ill have to see if i can pick up a copy of LROI
I think from memory it's the one with a cover pic of a Range Rover with an Aston Martin V12 under the bonnet - seriously mental!
Cant be that hard.... a mechanic does it...
isnt that what they say?....
Daz
Daz
I've completed enough DIY clutch and gearbox changes at home and in mates' sheds on smaller cars, that I'm not sure I don't want to do this myself.
Mind you it is only the transfer case coming out...
... can't be that hard...
Right?
Being under warranty I'm not sure I'm allowed too! ( apparently being a fitter and machinist doesn't count )
 OldBushie
						OldBushie
						The hard bit is bolting them together without damaging the input seal. Pat
