Results 1 to 10 of 11
Thread: Dash lights ?
    farm rover Guest
    Dash lights ?
    Hi all, i hope someone here can give me some clues on where to look at fixing this fault i have . The car is a 2002 TD5 Manual, and while i was towing my box trailer all of a sudden the dash lights just disappeared . Along with the dash lights was the rear right tail light . I have checked every fuse and bulb but haven't found a failed one yet .
    Has anyone else experienced this before?
    Bill.
    Jul 2014
    west of Transylvania
    Hi, double check(or better replace with new to be 100%) fuse F33 interior fusebox... if that's good the problem might be complicated
    Jan 2013
    Tasmania
    Happened to me tonight.
    Fuse 33...
    farm rover Guest
    Thanks , i'll check it again in the morning .
    farm rover Guest
    Ok ! I finally got around to checking the #33 fuse and its fine . I put a new one in but to no avail.... I have checked the wiring in the rear and can't find a thing . Any ideas ? Thanks.
    Jul 2014
    Do you have RAVE? cos i can tell you where to measure if you are up to do that but the connector views from the electrical library are compulsory for that...BTW, the front RH side light is working?
    Perth WA 6149
    Also check fuse 9, 30 amps in the under bonnet fuse box. When I lost my dash lights this one had blown and I eventually traced my problems to a dicky indicator stalk.
    http://www.aulro.com/afvb/discovery-...em-solved.html
    Steve
    Jul 2014
    Quote Originally Posted by Rok_Dr View Post
    Steve
    On pre-facelift modells F9 is for the fuel burning heater and trailer permannent live... IMO it can't affect the dash lights at all, not even removed ...provided the diagram is not wrong
    Perth WA 6149
    Quote Originally Posted by sierrafery View Post
    Same for the face lift d2a here. Yes it isn't logical but I found the tip in the good oil part of the forum and it along with replacing the indicator stalk fixed the problems or me. Perhaps in my case the dodgy indicator stalk blew the 30 amp fuse. I had been doing some towing, but not at the time I lost my dash lights.
    Steve
    farm rover Guest
    Thanks again guys, i do have rave somewhere on cd . I am fine doing mechanical work but electronics stumps me everyone and then.
