Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: On Board Air Compressor
    Oct 2011
    Falcon, WA
    G'day guys/girls, I am wanting to install an air compressor under the bonnet on my 2016 D4.
    I have just ordered a D3 Traxide dual battery kit as I will be able to fit an optima D34 on the drivers side after discussing this with Tim so this leaves in front of the main cranking battery a spot to install a compressor.
    It seams from this forum, most have mounted the ARB high output compressor's on their vehicles.
    Are these any good? I have read some reviews and there seems to be better compressors out there and they are a lot cheaper.
    I have also read that ARB are the only ones that can be installed under the bonnet but considering it will only be running when the bonnet is open, is this really an issue?
    It would be great to know your thoughts and also see some pics of your set ups if possible please?
    Darren
    Aug 2015
    I wonder if anyone has ever wired up an AMK Compressor for this. Would be great to be be able to use it as a spare suspension compressor too. Although probably be easier to just buy one of Gordons kits...
    Williams West Aust
    Personally,I would be looking at a decent portable compressor and running it off the anderson plug.Look up the ARB portable twin compressor.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    LRD414's Avatar
    Oct 2014
    I have done the same as Andrew suggests and am happy with the ARB unit.
    Quote Originally Posted by dwaters View Post
    Have a look at this thread:
    http://www.aulro.com/afvb/l319-disco...ide-setup.html
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Oct 2011
    Falcon, WA
    I also wondered about the air suspension compressor??
    It has a massive accumulator and I would assume it is activated via a pressure switch and the tank would surely have a higher pressure rating than your tyres.
    Would it be possible to tee into it and install an isolation valve and nitto air fitting connection point??
    You could also carry a spare portable compressor as an emergency?? Such as a compressor failure............
    Be interested to hear anyone's thoughts??
    Williams West Aust
    I was thinking that too.
    2 issues.
    Warranty,if you are using it to do something it wasn't designed to do and it fails,no claim.
    The AMK compressor is already at its duty limit or beyond as an OME compressor,so you are only stressing it further.
    Andrew
    Feb 2012
    Darwin
    I intend on mounting Traxide second battery in the drivers side battery box, hoping a yellow top will fit there and mount the ARB twin compressor in front of the main battery passenger side. I have done a quick trial holding their twin compressor on an angle and with a purpose made bracket it appeared as if it will fit.
    Cheers, Mungus.
    _________________
    MY14D4HSE, Nara Bronze, E-Diff, Vision Assist, Surround Cameras, LLAMS, ProSpeed Sliders/Compressor plate, Mitch Hitch,
    ARB Summit Bar, Runva 11XP, Traxide D3-DU, GOE Comp. Rims, D697 265/60R18, Rijidij RWC, Fyrlyts.
    Feb 2016
    Hi Darren , I have a small ARB compressor under the bonnet, in front of the main battery, pumps up tyres very quick also has a pressure switch so i don't have to turn it off when changing to the next tyre
    Jul 2013
    Perth WA
    Mine is similar a similar set up, just an older compressor. Still going strong though.
    Scott.
    Sent from my GT-N5120 using AULRO mobile app
    Babs Guest
    Quote Originally Posted by Mungus View Post
    I don't believe the Yellow Top fits on the drivers side, just had mine fitted by DPL and they said they tried but to no avail, in saying that I don't know how hard they tried. So my Yellow Top sits in front of the main.
    Oh and they charged me 6hrs fitting time for my Traxide
    Cheers, Babs Sent from my iPhone using Forum Runner
