Hi,
Thanks for that. I can see many Brownie points coming my way from the Mrs.
A few people have asked about the mod to allow Puma electric Windows to be operated with the ignition off.
Make up a 2 cm jumper cable with 10 amp cable.
Connect to the window relay block found in the drivers side fuse location as per the attached photo.
And jobs done. Your windows should now be able to operate irrelevant to the key position.
Any issue with your vehicles electrics is your responsibility, but this is fault free in my experience and with my electrical system.
Best wishes all.
Ken
Hi,
 Master
						Master
						Thanks Ken, took longer to find the spade terminals in the shed than to do the job!
Maybe we need a thread on Best Mod For Your Buck...
Rich.
Hi Rich.
You're welcome mate. It really is a great little useful mod eh!
Ken
If you'd all read the Good Oil this mod was posted a few years ago by Alien..
Well worth reading the good oil people!!!
Nope that trick did not suit me.
I noticed as soon as I bridged the contacts my dash cam turned on and my cruise control lights activated.
Nevermind
2015 Defender 110
You can also do a similar set up but timed so it shuts off after a period..
Using one of these... gives enough time to remember and then safely de-energises the circuit.
I actually thought that was an oil thread. Seriously!
Some good stuff in there.
Thanks for the tip Tombie!
Ken
You beauty.
I just ordered 2 of those relays, what a good idea.
I looked for an aussie place that sold them but couldnt find any for under $128 each, so I found this mob for about $60 each 12V Adjustable Delay Timer Relay (Delay ON/OFF) | 12 Volt Planet
2015 Defender 110
Great find Karlz.
I see they offer an intermittent (5 second) universal relay as well. I've just purchased this for the intermittent rear wiper function as well as the window delay relay. I'll create an account with this company, lots of interesting gear there, and good prices.
Thanks to both you and Tombie.
Good on you fellas.
Ken
