Results 1 to 10 of 11
Thread: Defender ARB (wrap around) bull bar recovery points
    Jan 2016
    Tolga FNQ
    Anchor Defender ARB (wrap around) bull bar recovery points
    Gday fellas.
    What recovery point options have you fitted to your
    late model ARB bars?
    I'm looking at improving my set up, and seeking examples to use as guides.
    Thanks for any advice.
    Ken
    May 2015
    Near Fremantle, WA
    I've got the ARB bullbar for my 2015 Defender, and I use the APT Fabrications steering guard which has built in recovery points.
    Aug 2015
    I've the same as SUrrufus.
    Defender MY 2015 110
    Adventures so far!!
    Cape York 2016 Bloomfield,OTT(Gunshot), Frenchmans,Border Ranges, Fraser Isl,Moreton Isl, Tassie(pyengana Jeep track & Montezuma falls).1770
    Jan 2016
    Tolga FNQ
    Thanks fellas.
    I'm purchasing an APT unit as well, as my Terrafirma doesn't allow access to the eyes due to interference with the bull bar.
    I've just found a solid, fit for purpose mounting point on either side of the bar which allows rated D shackles to fit. There's a fair bit of play, but it will suffice until I purchase the APT protector to hang my shackles from. (Attached photo from someone else's Defender with ARB bar.)
    Thanks again.
    Ken
    [/URL][/IMG]
    Marty90 Guest
    Quote Originally Posted by Baytown View Post
    Thanks fellas.
    Thanks again.
    Ken
    Hi Ken,
    I hope you don't intend to use that as your recovery point.The bullbar doesn't have one
    Torres Straits
    Straight from ARB
    "Integrates durable tow points in the Hi-Lift jack recesses"
    Integrated tow point - if you need a tow that to me is a recovery
    I have a strong dislike for dynamic recoveries and havent owned a dynamic strap for >10 years - so for me when I think recovery I think slow and steady as little load applied as possible.
    And soooo I sure as heck would use (and have used) the integrated tow point that Baytown has pictured.
    Each to their own
    s
    Aug 2015
    This has been done to death on another thread.
    Fundamentally the deluxe ARB B'Bar does not have any recovery points, that's why I and others have fitted an APT with integrated recovery point......Oh and it does a great job of protecting the steering arms!
    Act in haste,.....repent in leisure!!
    Adventures so far!!
    Aug 2013
    Sunshine Coast
    ARB Recovery Points
    I have spoken directly with ARB on this matter and was informed by the engineer that this point as shown in the photo above is not rated and is for 'static' recovery situations only, no 'dynamic' recovery whatsoever.
    XDrive
    Torres Straits
    I couldn't help myself
    My deluxe bar is held on with six m10 bolts in shear across vertical and horizontal planes
    There are no crush cans
    The tow points are directly in line with the chassis
    So a single 8.8 m10 has an ultimate tensile shear at 46kN
    A 12ooolb winch at stall can exert give or take 54kN
    Six m10 won't be the problem for max winch pull
    The rest of the design is so much nicer than my old tjm which I double line pulled off relentlessly
    As I said Baytown I'm going use them
    S
    Jan 2016
    Tolga FNQ
    Thanks for the comments fellas.
    I will use the tow points X 2 on either side of the bar should I need to be recovered, hopefully without snatching.
    I will prioritise the APT steering guard with tow eyes ASAP for snatching etc. I have rarely needed to be towed, and don't play in mud, so it's not a common occurrence.
    I've seen some great tow points on tubular bull bars with dedicated swivel shackle mounts. I wish ARB had thought of that, or I had purchased the tubular bars. They just look right on a Defender!
    I wonder if I could mount 2 tow hooks under the truck with the ARB bar insitu without interference?
    Thanks again for the replies.
    Ken
