Results 1 to 10 of 29
Thread: 300tdi Highway "cruising" sweet spot?
    Aug 2016
    Exclamation 300tdi Highway "cruising" sweet spot?
    Hello Guys!
    Just checking with everyone who has a 300tdi.... can these things cruise at 110kms comfortably ? Or do they start to rev-out etc...
    Part of research as ill be a Defender as an everyday driver where city trips will be a few times a week.
    Plz confirm
    Oct 2007
    Wantabadgery, N.S.W.
    My 130 is quite happy at 110
    Don.
    Jan 2016
    southern highlands NSW
    mine will happily do 110. hills are another story
    Jan 2010
    Perth S/W
    110 is no problem in my 97 130 300TDI . but I would say the sweet spot is more like 90 . Still pulls well but uses less fuel .
    Torres Straits
    If on standard tyres (235/85) 110 on the dial is less than 100 actual ....
    So if you want 110 actual you will be wringing a 300tdi for its keep
    But it will do it 125 on the guage
    Free Again Thanks Dan
    Tdi and sweet spot You are joking right These words should never be used in the same sentence
    A Tdi will do 110 all day every day just do`nt expect break neck performance or anything else exciting .
    But their is one amongst the ranks that say`s he blows V8 dunny door`s off from the light`s in a Tdi auto disco
    Aug 2012
    Logan,Queensland
    You will find the governor at 125km/h in fourth on 265/75/16
    '95 Defender 130 Single Cab
    HS2.8 TGV Powered
    98% of all Land Rovers built are still on the road.
    The other 2% made it home.
    Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    105 was the sweet spot in my old 110 hardtop...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Geelong, VIC
    My 130 is also sweet at about 105 indicated. That's on worn 255/85's which makes it about 100 true.
    110 true with a slight incline or headwind and I'm wringing it's neck so I'd say they don't do 110 comfortably in stock tune.
    Certainly not comfortably in the same way that an old falcon/commodore or any modern 4cyl car does.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by rangieman View Post
    Leave you behind looking for 2nd gear .
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
