Results 1 to 10 of 23
Thread: Tyre Width
    Sep 2015
    In the shed or 1000km from home
    Tyre Width
    Hey folks,
    Hoping someone on here knows or can point me in the right direction for info on legal tyre widths in WA.
    Apparently a tyre cant stick out past the body panel of the vehicle.
    If fitting wheel flares does this make the tyre legal (if it doesn't stick past the flare)?
    Also, would this apply only to the plastic/fibreglass flares or even the rubber skirting/flaring that so many blokes put on there wheel arches?
    Thanks for any info.
    There's a whole heap of stuff to be legal.
    Not protruding beyond guards
    Not exceeding maximum factory width by a certain amount
    Not exceeding diameter by specific amount
    Not increasing wheel track by more than 50mm overall...
    Back down the hill.
    It's not that simple. You can only increase the track by 25mm, so if you need flairs to cover the tyres, you're probably not legal anyway.
    Sep 2015
    What do you mean by track? Width between outermost part of each tyre where it touches the ground? No one on the street is going to know the millimetre distance of the factory wheel track on each vehicle make and model are they?
    Mar 2010
    antipodean
    Quote Originally Posted by Finnius View Post
    Their lawyers will.
    Sep 2015
    Anyone ever been in trouble for excessive wheel track width and not for how much their tyres stick out from the bodywork?
    So I presume flares increase the distance your tyres can stick out legally?
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by Fifth Columnist View Post
    Their lawyers will.
    Yes, If there is an accident where the tyres were seen to be the cause or part cause of the accident.
    To the OP - depends on what you're after and if and by how much you're willing to break the law. There's plenty of people running around on illegal tyre combinations and not a second glance is given.
    Chances of you getting into serious trouble - very, very low - but theoretically it is possible.
    Swansea, NSW
    Yes. Charlestown RTA, LJ Torana ,circa 1989, 14mm over track, 39mm overall given the 25mm we were allowed initially. They don't relax old rules, they just introduce new ones.
    Sep 2015
    I just read VSB 14:
    [ame="https://infrastructure.gov.au/roads/vehicle_regulation/bulletin/pdf/NCOP11_Section_LS_Tyres_Suspension_Steering_Nov_20 15_v4.pdf"]https://infrastructure.gov.au/roads/vehicle_regulation/bulletin/pdf/NCOP11_Section_LS_Tyres_Suspension_Steering_Nov_20 15_v4.pdf[/ame]
    And it says the tyres cant protrude past the bodywork (including flares).
    But it doesn't say what the flares have to be made of - so i guess the rubber ones legally allow you to run tyres that stick out past the factory bodywork...
    Wheel track is measured centre to centre.
    It's very easy to spot a modified track..
    In the same VSB here's some screen shots of relevant info...
