Page 1 of 7 123 ... LastLast
Results 1 to 10 of 63
Thread: What grease gun to get?
    May 2015
    Williamstown, Victoria
    The previous owner has put greasable joints in the prop shaft. I need a grease gun and now nothing about grease guns. Will one from fleabay or supercheap autobarn do?
    What size? 250ml or 500ml or what.
    Do I keep adding grease until clean grease comes out of the bearing?
    Bo
    Build date 11th Oct 2003
    LROCV #1410
    Apr 2015
    Bondi Junction
    I got a cheap one from supercheap. Does the job. Doesn't matter bout the size, it would just mean you need to refill the gun more often
    Free Again Thanks Dan
    Thought this might help
    [ame]https://youtu.be/1lZq8Yolk3o[/ame]
    the which grease gun is a little less important than the attachments it comes with.
    no, dont greae them until grease comes out. Just add one shot of grease every month or 2000-2500 km or so.
    if you notice grease only weeping past one of the seals you then need to belt the yoke of the UJ in a few different directions to change the path of resistance to the grease. in a perfect world you would put your one shot of grease in, go for the monthly 50 K check out drive and when you climbed under you would notice a slight dribble of grease from each arm of the UJ.
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    if you use cheap tools get a cheap grease gun , otherwise get a McNaught.
    Perth WA 6149
    Quote Originally Posted by ramblingboy42 View Post
    Agreed, many years ago I bought Their pistol version on special and it is still going strong.
    Steve
    And that`s what i own
    Oct 2007
    Wantabadgery, N.S.W.
    I have this one. It has the ability to deliver either high volume or high pressure, by shifting a bar above the handle. It's a handy feature.
    Don.
    99.87 MB
    I use the McNaught also, a good unit.
    Slunnie
    May 2015
    VIC
    spend the extra and grab a McNaught
