Results 1 to 10 of 28
Thread: Latest Jack recommendations
    Brisbane, Queensland
    I went to jack up the RRV last night to check a wheel bearing. My small trolley and D1 bottle jacks couldn't lift the car high enough. I think it's the consequence of the change to slightly bigger 265/60/18 tyres.
    It looks like I need a jack with a range of 200 to 460mm. Merc sprinter two stage jack would be good but rare.
    Any other suggestions.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Aug 2010
    Sunbury, VIC
    I used my good workshop jack at home and packed that when travelling a long way and remote places, and the RACV when out and about locally. . Thankfully never needed to change a tyre when out.
    Oct 2007
    Wantabadgery, N.S.W.
    If you can find an Iveco Daily jack from a wrecker, it'll do the job. Made by the same mob as the Defender/Disco red jack, but 3.5T cap. 141mm to 400mm height range. I got one from here for about $110 del'd.
    Don.
    Attached Files Attached Files
    Thanks.
    I have a red D1 jack. Too short on its own and too tall if on a block.
    REMLR # 137
    Oct 2014
    Does this one fit the bill with a piece of hardwood under as jacking plate?
    https://www.blackwoods.com.au/part/0...escopic-hyd-2t
    Capacity (kg) 2000
    Height Max (mm) 418
    Height Min (mm) 181
    Stroke (mm) 201
    Mass (kg) 5.7
    Alternatively can you jack using the suspension arm like on the D4?
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Thanks Scott, I tried looking for that one.
    Unfortunately the jack needs to be capable about 460mm height to get the wheel off the ground using the side jacking point. The car sits quite high with this amount of lift as the wheel really hangs.
    Part of the problem is I'm not really sure what can be used for a jacking point, other than designated points, subframe and suspension arms at the back which look substantial enough.
    REMLR # 137
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by rar110 View Post
    Apart from the jacking points, yes the subframe and suspension arms and the entire arse of the car can be lifted from the diff - but like most points you need a big jack to do this - I used this point when I had to do something on both sides like the brakes, etc - I have a large trolley jack that would pick it up high enough to get my jack stands under the rear jacking points.
    Once you've done that you get clear access to the entire rear suspension, brakes, everything.
    Thanks Gav, yes the rear is substantial. There are good options there which lift the wheel nicely. The front is a different story. The only clear options at the front are a jacking point or subframe. However neither lifts the wheel.
    REMLR # 137
    Aug 2010
    Sunbury, VIC
    You can lift a front wheel from the lower suspension arm if you drop it to access height first. It flattens out the arm enough for a trolley jack plate to lift just where there is a recess in the arm. Again, shortly followed by a jack stand, but that's where I always jacked the front from.
    This way you only need to to pump the jack a few times to get the wheel off the ground.
    Free Again Thanks Dan
    What about this
    2 ton , Min height 160mm , Max height 410mm
    High Quality Portable 2 Ton Hydraulic Bottle Jack Car Low Profile Safety Valve
