Thread: Supported audio formats
    PeterJ Guest
    Hi all, I have done a search but not found any information around supported audio formats. The owners manual states that the system will play MP3, WMA, WAV and AAC formats from a USB, I can only get it to play MP3.
    I ripped various CD's using Windows Media player in the WMA (also tried WMA lossless) MP3 and WAV (also lossless) formats and only MP3 would play.
    Also had a "what the" moment when I copied a folder across to the USB,plugged it into the car and the car deleted it Did it a couple of times because I thought I was loosing it, which I probably am.
    Anyway, has anyone else been through this, what was the fix?
    As per the tag below it is MY13 HSE, so Harmon Kardon system
    Dec 2011
    Bundeena
    Hey Peter, I ripped a whole stack of CDs to a USB which I was able to play on the MY10 HK system and now on the MY16 Meridian system. I can't remember what I used to do the job but it was on W7. I'll need to check what format I used but I'm pretty sure it was lossless - wanted the best possible quality.
    PS I thought the MY13 was the 1st to get the Meridian system.
    Sean
    Williams West Aust
    I too have had this problem.I put a stack of music on a USB,much of it wasn't visable or playable in my MY14 with the upgraded Meridian system.
    It was all copied via Windows on a Vista system.
    I have copies of the USB which I use in the boat and my grader.They too have issues,not playing all albums.They have issues with different albums.Some were ripped from CD,others purchased online and downloaded(not ITunes)
    I have noticed the USB in the D4 now plays and sees all so perhaps there was a patch put in whilst it was getting serviced???
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    PeterJ Guest
    Hi Sean, thanks, my car was at the change over point, delivered Dec 13 so HK system. Same as you I am looking for the best quality and I don't understand why it won't play WAV files, I have tried 3 different ripping programs, all on W10. I did not really think that would be the problem but you look at all sorts and I will look into updates with the dealer, thanks Andrew.
    Peter
    Jun 2008
    McMinns Lagoon NT
    What bit rate are the WAV files? I have never used Windows Media Player to rip a CD so don't know what options it has (using Android tablet to type this so can't check). One would assume that CD audio being 44.1kHz 16 bit then it should be that when the WAV is produced. It would also be advantageous to know what 'Wav's' the HKsystem will play.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Mar 2015
    The onboard system will not play any losess formats including wav and flac files on any android or usb direct connection unless you have purchased the optional Landrover Apps system that adds a second usb port in the glovebox. You then use an app on your phone to make it work. Best option i have found to date is either CD quality or to rip your CDs to mp3 @ 320kbs and then load them on a usb or mp3 player.
    Jun 2008
    McMinns Lagoon NT
    Back on the Windows 7 computer now and checked WMP and while it says WAV (lossless) there are no other selectable settings.
    I have for over 10 years used CDex to rip CD's - free download program. This allows you to select the WAV encoder and then select a sample rate (of which 44.1kHz (and 16 bit) is an option) This is the same as CD audio.
    PS - apom posted while I was typing this!
    Cheers, Dale
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    PeterJ Guest
    Quote Originally Posted by apom View Post
    Yes I see apom, thanks, I was reading a different version owners manual which stated WAV was supported, having pulled mine from the car I now see it only supports MP3, WMA and AAC.
    I have tried WMA(lossless) but as per your comment it does not play them, so I might explore some other options. Even with MP3 at 320kbs you get a fairly big change in the file and while I was wanting to play the ripped CD's in the car it was also about a backup for the music collection, which I want in original quality.
    Narangga, bit rate for WAV files is channels * bits per sample * sample freq so in this case 2*16*44100 = 1.4 Mbs which is why you end up with 600MB+ files, but memory is cheap these days.
    I guess I'll do some more research and see what the options are......thanks
    Peter
    Williams West Aust
    Peter.
    Does you have factory sat nav????
    If so,the later ones can store CDs on the Nav hard drive,worth looking into.There is a video on you tube how to store Cds onto land rover stereo.
    Andrew
    PeterJ Guest
    Hi Andrew, yes it does and yes I do, thanks for the thought.....
    Peter
