how much did that set you back?
Well we put this in the camper last week with the help of Phil (Discowhite) and tested it out up at the Watagans, works great, just like showering at home.
Bosch continuous gas hot water system.
Cheers Baz.
2007 BMW R1200GS
2007 Discovery 3 SE7 TDV6 2.7
2012 SZ Territory TX 2.7 TDCi
$324 at Camec/RVaccessories was a factory second, normally they are around the $450 to $500 mark, there are others apart from Bosch but the Bosch is better as it is gas only no power required.
Baz.
Cheers Baz.
2007 BMW R1200GS
looks like a good bit of gear...
<span style="color:blue">it does use a couple of batteries doesnt it....(just to ignite the burner)....
that is a much better idea than the heat exchange units that run on engine heat....
you dont have to wait for the engine to heat up before you can have a hot shower....
im not saying diesels take forever to warm up.......
.....MUCH!!! </span> 8O
What happened to the boil a billy and pour it over you........
Luxo-barge trailer. [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img] [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img] [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img]
Is that one of those heaters where the water pressure turns over the igniter?
If so do you have problems with it starting up?
Simon.
where did u install it in the camper ? does it take much gas ?
guess u just need a good water source now for those long hot showers [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img][img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
Matt.
How much water does it hold???
<span style="color:blue">it doesnt hold water...its what is known as an instantaneous hot water system......
it heats it up as it flows through it.....</span>
