Results 1 to 6 of 6
Thread: Horn button spring
    Horn button spring
    I've lost a spring inside my horn button. Don't know what it looks like, or even exactly where it goes. I don't want to replace the whole switch. I do have the missing plastic cap/end
    Feb 2013
    Sydney, NSW.
    The Spring is 24mm long and 12mm in diameter.
    In the plastic end cap is a brass/copper contact that is pushed over the White center piece. The Spring must be of a larger diameter than the contact....
    If you have a look in the end cap there are four raised bits (on the + section in there).
    The Spring sits on them, NOT in the recessed bits next to the center contact.
    Regards,
    Mike.
    Feb 2013
    Sydney, NSW.
    Spring diameter...=12mm.
    Feb 2013
    Sydney, NSW.
    The Spring must sit on the outer raised bits of the + section inside the hole.
    Feb 2013
    Sydney, NSW.
    Sorry about the multiple posts, but my iPad doesn't let me post multiple images in the one post...
    Not sure why.
    Mike.
    That's exactly the advice I needed.
    As it happens, the closest spring that I had to hand was 10mm dia. I used a little bit of unshrunk heat shrink to stop the spring shorting the contacts and seem to be back in business
