Results 1 to 3 of 3
Thread: High/Low shifting cable loose
    Matthoogland Guest
    Hi,
    I'm having some trouble with shifting from low to high on my recently acquired D2. From beneath the vehicle I can see the cable switch is coming out of its bracket, so that all tension is lost in the cable and the gear lever becomes useless. If I clamp it together with vice grips I can get it working but obviously is not a permanent solution.
    It seems to be missing a ring clip or something to hold the cable in place against the bracket. I've tried screwing on a hose clamp but it didn't work out.
    (Not sure of the right terminology but hopefully I've explained myself OK(.
    Does anyone know what the particular part is that I need and where I can get it?
    Jan 2014
    Perth Western Australia
    If you mean the outer sheath on the shifter end of the cable is moving away from the bracket then you need a good old...
    NTC 5147
    Daz
    Daz
    Matthoogland Guest
    Yep, that's what I mean, and that looks exactly like what I'm after. Cheers Daz!
