Thread: Divers Window stopped working
    Gormo Guest
    My 2000 disco Drivers Window stopped working but all other windows work. I've tested the switch which is ok.There is a clicking sound coming from the glove box area. I have read that it's possibly ECU or BDU unit does anyone have some advice please?
    May 2015
    Williamstown, Victoria
    The BCU is behind the passenger glove box. I would have thought you would've had a reply from some of the more experienced ones here.
    RAVE might help.
    Build date 11th Oct 2003
    LROCV #1410
    May 2015
    The electric block diagram from RAVE has a rhs front switch and motor connected to the BCU. The only relay is for the rear windows.
    LROCV #1410
    Free Again Thanks Dan
    Quote Originally Posted by Gormo View Post
    Pop the trim off more than likely the window regulator as they have dumb plastic slides. If it has not bent the regulator up too bad you can buy door rollers from Bunnings drill some holes fit the rollers all good
    Jul 2014
    west of Transylvania
    +1^^^ ...or chaffed wiring where the loom meets the door frame
