Results 1 to 10 of 20
Thread: All Alloy D2a TD5 radiator that is not $1K Allisport
    Jun 2011
    Victoria - Pakenham
    Has anyone fitted an all alloy radiator to a TD5 from Ebay? I need to replace mine as i've snapped the overflow return line off, i've also put the screw through the tank by mistake before. So figured i may as well replace it, I seen these and thought it might be better than a plastic tank one.
    Example below.
    3 ROW ALLOY RADIATOR For 99-04 LAND ROVER DISCOVERY 2.5 TD5 DIESEL
    Free Again Thanks Dan
    Quote Originally Posted by Jazzman View Post
    Example below.
    Looking for a Wood Duck
    Some say the weld`s look average which they do but i think there is a member or 2 on here that run the same or similar in There D2`s but i think they are reluctant to post for fear of condemnation
    Byford, WA
    Hi Jazzman,
    I've fitted an Ally radiator made or at least sold by ASI, also bought off Fleabay, I didn't buy one for a TD5, it was somethng else. Personally I had no problem with the radiator or the quality, looked good and also hadn't failed when I sold and moved onto something else.
    Cheers Marty
    Jun 2011
    Victoria - Pakenham
    Quote Originally Posted by rangieman View Post
    I thought that might be the case, but sadly that kind of thing seems to only happen in the D2 section of this forum.
    Jun 2011
    Victoria - Pakenham
    Quote Originally Posted by Nomad9 View Post
    Hi Jazzman,
    Cheers Marty
    Thanks for the feedback mate.
    Jul 2010
    Hunter Valley NSW
    If you dont use Bendix brake pads or even consider removing the ACE system the D2 elitists will condemn you
    Quote Originally Posted by northiam View Post
    Im so bad my car does not have ACE and i dont have Bendix pads But i do have Delios slotted rotors and pads and coil springs
    Jan 2011
    Gippsland
    why would you remove ACE? - it allows me to drive my D2 on the dirt the same way I drive my Subaru
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
    Jan 2014
    coonarr qld
    Hi Jazzman
    I fitted one of these about 18 mths ago when I broke off the overflow spiggot ( I have since refitted the old one after working out how to fix it) You will have to block off one of the small pipes at the bottom and block off and drill a smaller hole in the other.I used some alloy rod a mate turned down to size and glued them in with jb weld.It is also worth cutting out the slot that the transmission oil cooler slides in and use a different method of securing it or you will have to disconnect the oil pipes to fit it. Be careful when refitting the intercooler and make sure the locating pegs fit in the brackets on the side of the radiator or you will wear a hole in the air con condenser(I found out the hard way). I had it fitted for about 20,000 ks without any problem and it was still fine when I removed it,it seemed to run slightly cooler.
    Jan 2011
    Gippsland
    Quote Originally Posted by sharmy View Post
    Hi Jazzman
    if possible pics would assist please......
    LROCV member #131
